Introdução
Retirez la vitre arrière pour accéder aux composants à l'intérieur de votre iPhone 4.
Ferramentas
Peças
Vídeo de Apresentação
Sur le boîtier arrière de votre iPhone, vous trouverez deux vis cruciformes #000 ou des vis "Pentalobe" 5 points Apple. Vérifiez de quelles vis il s'agit et prévoyez un tournevis adapté pour les enlever.
Retirez les deux vis de 3,6 mm Pentalobe ou cruciformes #000 près du connecteur de dock.
Pour remonter votre appareil, suivez les étapes dans l'ordre inverse.
113 outras pessoas concluíram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
4 comentários
Step 1 says the screwdriver should only be used once. Is this correct? Or should it read the screws should only be used once?
This was a remark made in the products section for the rear glass panel on the Verizon CDMA, "The instructions don't tell you to make sure that you remove the plastic lens from the front facing camera." It is referring to the protective plastic film on the new rear panel that protects the new lens. This should definitely be included in the instructions for replacement of the back panel.
