Ir para o conteúdo principal
Redmi Note 9 Pro Loudspeaker Replacement
O que você precisa
  1. Redmi Note 9 Pro Loudspeaker Replacement, Heat the rear glass: passo 1, imagem 1 %32
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Pergunte ao FixBot
    Comentar
  2. Redmi Note 9 Pro Loudspeaker Replacement, Insert an opening pick: passo 2, imagem 1 %32 Redmi Note 9 Pro Loudspeaker Replacement, Insert an opening pick: passo 2, imagem 2 %32 Redmi Note 9 Pro Loudspeaker Replacement, Insert an opening pick: passo 2, imagem 3 %32
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  3. Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: passo 3, imagem 1 %32 Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: passo 3, imagem 2 %32
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  4. Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: passo 4, imagem 1 %32 Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: passo 4, imagem 2 %32 Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: passo 4, imagem 3 %32
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  5. Redmi Note 9 Pro Loudspeaker Replacement: passo 5, imagem 1 %32 Redmi Note 9 Pro Loudspeaker Replacement: passo 5, imagem 2 %32
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  6. Redmi Note 9 Pro Loudspeaker Replacement: passo 6, imagem 1 %32 Redmi Note 9 Pro Loudspeaker Replacement: passo 6, imagem 2 %32
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    Pergunte ao FixBot
    Comentar
  7. Redmi Note 9 Pro Loudspeaker Replacement, Remove the rear glass: passo 7, imagem 1 %32 Redmi Note 9 Pro Loudspeaker Replacement, Remove the rear glass: passo 7, imagem 2 %32
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    Pergunte ao FixBot
    Comentar
  8. Redmi Note 9 Pro Loudspeaker Replacement, Unfasten the motherboard cover screws: passo 8, imagem 1 %32
    • Use a Phillips screwdriver to remove the eleven 3.9 mm-long screws securing the motherboard cover.
    Pergunte ao FixBot
    Comentar
  9. Redmi Note 9 Pro Loudspeaker Replacement, Pry up the motherboard cover: passo 9, imagem 1 %32 Redmi Note 9 Pro Loudspeaker Replacement, Pry up the motherboard cover: passo 9, imagem 2 %32
    • Insert the tip of an opening pick underneath the left edge of the motherboard cover.
    • Flip the opening pick sideways to pry up the motherboard cover.
    Pergunte ao FixBot
    Comentar
  10. Redmi Note 9 Pro Loudspeaker Replacement, Remove the motherboard cover: passo 10, imagem 1 %32 Redmi Note 9 Pro Loudspeaker Replacement, Remove the motherboard cover: passo 10, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers or your fingers to remove the motherboard cover.
    Pergunte ao FixBot
    Comentar
  11. Redmi Note 9 Pro Loudspeaker Replacement, Disconnect the battery cable: passo 11, imagem 1 %32 Redmi Note 9 Pro Loudspeaker Replacement, Disconnect the battery cable: passo 11, imagem 2 %32
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    Pergunte ao FixBot
    Comentar
  12. Redmi Note 9 Pro Loudspeaker Replacement, Unfasten the loudspeaker assembly screws: passo 12, imagem 1 %32
    • Use a Phillips screwdriver to remove the seven 3.9 mm-long screws securing the loudspeaker assembly.
    Pergunte ao FixBot
    Comentar
  13. Redmi Note 9 Pro Loudspeaker Replacement, Pry up the loudspeaker assembly: passo 13, imagem 1 %32 Redmi Note 9 Pro Loudspeaker Replacement, Pry up the loudspeaker assembly: passo 13, imagem 2 %32
    • Insert an opening pick into the gap between the top edge of the loudspeaker assembly and the battery.
    • Use your opening pick to pry up the loudspeaker assembly.
    Pergunte ao FixBot
    Comentar
  14. Redmi Note 9 Pro Loudspeaker Replacement, Remove the loudspeaker assembly: passo 14, imagem 1 %32 Redmi Note 9 Pro Loudspeaker Replacement, Remove the loudspeaker assembly: passo 14, imagem 2 %32
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    Pergunte ao FixBot
    Comentar
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
6 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
261.093 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 30.017 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 134
Ao todo: 6,003
