Ir para o conteúdo principal
RazorX DLX Electric Skateboard Battery Replacement
O que você precisa
  1. RazorX DLX Electric Skateboard Battery Replacement, Battery: passo 1, imagem 1 %32 RazorX DLX Electric Skateboard Battery Replacement, Battery: passo 1, imagem 2 %32 RazorX DLX Electric Skateboard Battery Replacement, Battery: passo 1, imagem 3 %32
    • Flip the skateboard upside down.
    • Use a 4 mm Allen key to remove the 25 mm bolt that secures the cover.
    • Push the cover forward to slide it off.
  2. RazorX DLX Electric Skateboard Battery Replacement: passo 2, imagem 1 %32
    • Disconnect the battery and slide it out.
    • Lithium-ion batteries should not be punctured, heated or improperly disposed of.
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Emmett Normand
Membro desde: 10/24/24
971 Reputação
Autoria de 8 guias
Equipe
Cuesta, Team 20-4, Krynen Fall 2024 Membro de Cuesta, Team 20-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G4
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 64
