Introdução
This guide will show you how to replace the battery on your RazorX DLX Electric Skateboard. The battery is the fuel source for operating the skateboard. Take caution when handling the battery during replacement. Before you start, make sure the device is powered off.
O que você precisa
Flip the skateboard upside down.
Use a 4 mm Allen key to remove the 25 mm bolt that secures the cover.
Push the cover forward to slide it off.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
