Ir para o conteúdo principal
Razer DeathAdder V3 Pro USB-C Port Replacement
O que você precisa
  1. Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: passo 1, imagem 1 %32 Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: passo 1, imagem 2 %32 Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: passo 1, imagem 3 %32
    • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
    • Remove the three 7 mm screws using a Torx T6 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Razer DeathAdder V3 Pro USB-C Port Replacement: passo 2, imagem 1 %32 Razer DeathAdder V3 Pro USB-C Port Replacement: passo 2, imagem 2 %32
    • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
    • Insert a spudger into the seam between the top and bottom shells.
    • Gently work around the edges unclipping the internal latches.
    • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
    • Carefully pull the shells apart to unplug the cable in the front.
    Pergunte ao FixBot
    Comentar
  3. Razer DeathAdder V3 Pro USB-C Port Replacement: passo 3, imagem 1 %32 Razer DeathAdder V3 Pro USB-C Port Replacement: passo 3, imagem 2 %32
    • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
    Pergunte ao FixBot
    Comentar
  4. Razer DeathAdder V3 Pro USB-C Port Replacement, USB-C Port: passo 4, imagem 1 %32
    • Use a T6 Torx screwdriver to remove the 5mm screws from the circuit board.
    • Unplug the battery from its connection on the right.
    • Be careful not to break the two clips that hold the PCB at the front of the mouse.
    • Remove the circuit board from the mouse.
    Pergunte ao FixBot
    Comentar
  5. Razer DeathAdder V3 Pro USB-C Port Replacement: passo 5, imagem 1 %32
    • Always solder in a well ventilated area.
    • Apply solder to the four anchor points on the back corners and side of the USB-C port.
    • Once the solder has melted, use tweezers to remove the USB-C port.
    • Use a solder sucker to clean the area.
    Pergunte ao FixBot
    Comentar
  6. Razer DeathAdder V3 Pro USB-C Port Replacement: passo 6, imagem 1 %32
    • Apply flux, then apply solder to one anchor point to help line up the new USB-C port.
    • Once the USB-C port is aligned, apply flux to the other three anchor points and solder them.
    Pergunte ao FixBot
    Comentar
Conclusão
Nicholas
Membro desde: 09/24/25
453 Reputação
Autoria de 4 guias
Equipe
Texas Tech, Team 2-5, Johansen Fall 2025 Membro de Texas Tech, Team 2-5, Johansen Fall 2025
TTU-JOHANSEN-F25S2G5
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 47
Ao todo: 308
