Introdução
If your Razer BlackShark V2 is producing choppy, interrupted, or no audio, your headset’s speaker(s) may be damaged (to confirm diagnoses & solutions, see Razer Blackshark V2 Troubleshooting Page, "Audio Cutting Out" or “No Audio at All”). This guide will assist you in the replacement of this component.. Be sure to be mindful of which layers of the headset assembly you're taking apart and that you don't adversely damage the holds, small wires, ear cushions, ear cushions’ rubber linings or plastic ridges, or headset itself when applying pressure.
O que você precisa
Remove the four screws holding the speaker in the headset using a Phillips #1 screwdriver.
Uma outra pessoa concluiu este guia.
