Ir para o conteúdo principal
RCA RCT6378W2 Battery Replacement
O que você precisa
  1. RCA RCT6378W2 Battery Replacement, Battery: passo 1, imagem 1 %32 RCA RCT6378W2 Battery Replacement, Battery: passo 1, imagem 2 %32 RCA RCT6378W2 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the two 2.4 mm x 4 mm Phillips #00 screws from the bottom of the tablet.
    Pergunte ao FixBot
    Comentar
  2. RCA RCT6378W2 Battery Replacement: passo 2, imagem 1 %32 RCA RCT6378W2 Battery Replacement: passo 2, imagem 2 %32 RCA RCT6378W2 Battery Replacement: passo 2, imagem 3 %32
    • Remove the back cover with a plastic opening tool, exposing the battery and motherboard.
    Pergunte ao FixBot
    Comentar
  3. RCA RCT6378W2 Battery Replacement: passo 3, imagem 1 %32 RCA RCT6378W2 Battery Replacement: passo 3, imagem 2 %32 RCA RCT6378W2 Battery Replacement: passo 3, imagem 3 %32
    • Remove the two black tape strips from the battery pack.
    Pergunte ao FixBot
    Comentar
  4. RCA RCT6378W2 Battery Replacement: passo 4, imagem 1 %32 RCA RCT6378W2 Battery Replacement: passo 4, imagem 2 %32 RCA RCT6378W2 Battery Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the battery pack by carefully prying the battery back from the front cover. Then, remove the wires connecting the battery to the motherboard at the motherboard using the tweezers.
    Pergunte ao FixBot
    Comentar
  5. RCA RCT6378W2 Battery Replacement: passo 5, imagem 1 %32
    • Replace the damaged or malfunctioning battery with the new battery and wires. The new battery must be stuck back into its original place using thermal tape.
    Pergunte ao FixBot
    Comentar
  6. RCA RCT6378W2 Battery Replacement: passo 6, imagem 1 %32 RCA RCT6378W2 Battery Replacement: passo 6, imagem 2 %32 RCA RCT6378W2 Battery Replacement: passo 6, imagem 3 %32
    • The new wires must be soldered back into place on the motherboard at the original location.
    • For tips on soldering techniques, see this Soldering Guide.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Justin
Membro desde: 01/29/15
425 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 14-4, Shirley Spring 2015 Membro de Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Membros
Autoria de 15 guias
7Comentários do guia
Links on ordering replacement batteries
Great step by step instructions not for novices!
Robert Groffel - Responder Compartilhar
i liked good job
Luis Orellana - Responder Compartilhar
Can you give information about this battery?
What type of battery is it?
Is Applicable under the Dangerous Goods Regulations?
carlos - Responder Compartilhar
where do i order the battery for RCT6378W2
Michael Giulian - Responder Compartilhar
RCT6378W2 where can i get a replacement battery
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 71
Ao todo: 27,905
