Ir para o conteúdo principal
RCA RCT6272W23 Rear Camera Replacement
O que você precisa
    1. RCA RCT6272W23 Rear Camera Replacement, Case: passo 1, imagem 1 %32 RCA RCT6272W23 Rear Camera Replacement, Case: passo 1, imagem 2 %32
      • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
      Pergunte ao FixBot
      Comentar
    2. RCA RCT6272W23 Rear Camera Replacement: passo 2, imagem 1 %32 RCA RCT6272W23 Rear Camera Replacement: passo 2, imagem 2 %32
      • Press the plastic opening tool into the space between the front and back portions of the case.
      • Run it along the perimeter of the device to unhook the plastic tabs.
      • Gently pull both sides apart.
      • The speaker is connected to the back cover, so be careful when separating.
      Pergunte ao FixBot
      Comentar
    1. RCA RCT6272W23 Rear Camera Replacement, Motherboard: passo 3, imagem 1 %32 RCA RCT6272W23 Rear Camera Replacement, Motherboard: passo 3, imagem 2 %32 RCA RCT6272W23 Rear Camera Replacement, Motherboard: passo 3, imagem 3 %32
      • Use a soldering iron to remove the soldered connections on the motherboard
      • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
      • For more information about soldering, check out this guide.
      Pergunte ao FixBot
      Comentar
    2. RCA RCT6272W23 Rear Camera Replacement: passo 4, imagem 1 %32
      • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
      Pergunte ao FixBot
      Comentar
    3. RCA RCT6272W23 Rear Camera Replacement: passo 5, imagem 1 %32 RCA RCT6272W23 Rear Camera Replacement: passo 5, imagem 2 %32
      • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
      Pergunte ao FixBot
      Comentar
    4. RCA RCT6272W23 Rear Camera Replacement: passo 6, imagem 1 %32
      • Pull up the motherboard from the rest of the body.
      Pergunte ao FixBot
      Comentar
    1. RCA RCT6272W23 Rear Camera Replacement, Rear Camera: passo 7, imagem 1 %32
      • Using a spudger, gently pry off the camera from the back of the display
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Michigan Tech, Team 1-5, Lauer Spring 2015 Membro de Michigan Tech, Team 1-5, Lauer Spring 2015
MTU-LAUER-S15S1G5
2 Membros
Autoria de 36 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 42
Ao todo: 664
