Introdução
In this guide, you will learn how to replace the display screen on your RCA RCT6272W23 tablet.
O que você precisa
Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
Use a soldering iron to remove the soldered connections on the motherboard
4 outras pessoas executaram este guia.
