Ir para o conteúdo principal
Protocol Dronium III AP Light Bulb Replacement
O que você precisa
  1. Protocol Dronium III AP Light Bulb Replacement, Drone Battery Pack: passo 1, imagem 1 %32 Protocol Dronium III AP Light Bulb Replacement, Drone Battery Pack: passo 1, imagem 2 %32
    • Ensure the drone is powered off.
    • Press in and lift battery compartment cover.
    • A soft pry tool may be used for easier access.
    Pergunte ao FixBot
    Comentar
  2. Protocol Dronium III AP Light Bulb Replacement: passo 2, imagem 1 %32
    • Remove battery pack from body of drone.
    Pergunte ao FixBot
    Comentar
  3. Protocol Dronium III AP Light Bulb Replacement: passo 3, imagem 1 %32 Protocol Dronium III AP Light Bulb Replacement: passo 3, imagem 2 %32
    • Disconnect white connectors between the battery pack and drone.
    Pergunte ao FixBot
    Comentar
  4. Protocol Dronium III AP Light Bulb Replacement, L.E.D. Bulb(s): passo 4, imagem 1 %32
    • Remove the eight (8) 5mm Philips screws attaching the motor arms to the body using a Philips J00 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Protocol Dronium III AP Light Bulb Replacement: passo 5, imagem 1 %32 Protocol Dronium III AP Light Bulb Replacement: passo 5, imagem 2 %32
    • Remove the six (6) 5mm Philips screws attaching the Body Cover to the Body of the drone using a Philips J00 screwdriver.
    • Remove the Body Cover.
    Pergunte ao FixBot
    Comentar
  6. Protocol Dronium III AP Light Bulb Replacement: passo 6, imagem 1 %32 Protocol Dronium III AP Light Bulb Replacement: passo 6, imagem 2 %32
    • Remove the two (2) 5mm Philips screws attaching the Motherboard to the body of the drone using a Philips J00 screwdriver.
    • Lift the Motherboard off the mounting position.
    • Do not pull hard on the Motherboard as solder connections are fragile.
    Pergunte ao FixBot
    Comentar
  7. Protocol Dronium III AP Light Bulb Replacement: passo 7, imagem 1 %32 Protocol Dronium III AP Light Bulb Replacement: passo 7, imagem 2 %32
    • This step contains a tool that can present a potential burn hazard.
    • Prepare and warm up a soldering iron.
    • Position Motherboard so that the L.E.D. bulb solder joints are accessible.
    • Use the soldering iron to melt the solder joints.
    • For more detailed instructions on how to solder, visit out How to Solder and Desolder Connections guide.
    • Remove the L.E.D. bulb from the Motherboard
    Pergunte ao FixBot
    Comentar
Conclusão
Steven Mooers
Membro desde: 10/18/17
401 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G1, Rose Fall 2017 Membro de UW Tacoma, Team S1-G1, Rose Fall 2017
UWT-ROSE-F17S1G1
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 416
