Ir para o conteúdo principal
ProntoTec Axius Motherboard Replacement
O que você precisa
    1. ProntoTec Axius Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table.
      Pergunte ao FixBot
      Comentar
    2. ProntoTec Axius Motherboard Replacement: passo 2, imagem 1 %32
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Pergunte ao FixBot
      Comentar
    3. ProntoTec Axius Motherboard Replacement: passo 3, imagem 1 %32
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Pergunte ao FixBot
      Comentar
    4. ProntoTec Axius Motherboard Replacement: passo 4, imagem 1 %32 ProntoTec Axius Motherboard Replacement: passo 4, imagem 2 %32
      • Remove only the yellow tape that touches the motherboard
      • Be careful not to cut or damage the wires (red and black) that connect the battery to the motherboard.
      Pergunte ao FixBot
      Comentar
    5. ProntoTec Axius Motherboard Replacement: passo 5, imagem 1 %32 ProntoTec Axius Motherboard Replacement: passo 5, imagem 2 %32 ProntoTec Axius Motherboard Replacement: passo 5, imagem 3 %32
      • Use a Phillips screwdriver (PH00) to unscrew the two screws that connects the motherboard to the device
      • Be careful not to cut or damage the wires (red and black) that connect the motherboard to the battery.
      Pergunte ao FixBot
      Comentar
    6. ProntoTec Axius Motherboard Replacement: passo 6, imagem 1 %32 ProntoTec Axius Motherboard Replacement: passo 6, imagem 2 %32
      • Using a soldering iron, desolder the contact points of the speaker, battery and screen on the motherboard
      • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
      • Use pliers to pull the wire from the board
      Pergunte ao FixBot
      Comentar
    7. ProntoTec Axius Motherboard Replacement: passo 7, imagem 1 %32 ProntoTec Axius Motherboard Replacement: passo 7, imagem 2 %32
      • Using the spudger, disconnect the ribbon cable connecting the camera to the motherboard
      Pergunte ao FixBot
      Comentar
    8. ProntoTec Axius Motherboard Replacement: passo 8, imagem 1 %32 ProntoTec Axius Motherboard Replacement: passo 8, imagem 2 %32 ProntoTec Axius Motherboard Replacement: passo 8, imagem 3 %32
      • Using the spudger, push the black tabs towards the ribbon cable to unlock the ribbon cables that connect the screen to the motherboard.
      • Gently pull and remove the ribbon cables from the motherboard
      Pergunte ao FixBot
      Comentar
    9. ProntoTec Axius Motherboard Replacement: passo 9, imagem 1 %32 ProntoTec Axius Motherboard Replacement: passo 9, imagem 2 %32
      • Using the flat side of the spudger, lift up the mother board to disconnect from the screen.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Estelle Hatem
Membro desde: 10/20/16
156 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 5-3, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 638
