Ir para o conteúdo principal
PowerBook G3 Pismo Processor Replacement
O que você precisa
  1. PowerBook G3 Pismo Processor Replacement, Keyboard: passo 1, imagem 1 %32
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
    Pergunte ao FixBot
    Comentar
  2. PowerBook G3 Pismo Processor Replacement: passo 2, imagem 1 %32
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
    Pergunte ao FixBot
    Comentar
  3. PowerBook G3 Pismo Processor Replacement: passo 3, imagem 1 %32
    • Your laptop should look approximately like this.
    Pergunte ao FixBot
    Comentar
  4. PowerBook G3 Pismo Processor Replacement, Heat Shield: passo 4, imagem 1 %32
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
    Pergunte ao FixBot
    Comentar
  5. PowerBook G3 Pismo Processor Replacement: passo 5, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  6. PowerBook G3 Pismo Processor Replacement, Airport Card: passo 6, imagem 1 %32
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
    Pergunte ao FixBot
    Comentar
  7. PowerBook G3 Pismo Processor Replacement: passo 7, imagem 1 %32
    • Disconnect the antenna cable from the Airport card.
    Pergunte ao FixBot
    Comentar
  8. PowerBook G3 Pismo Processor Replacement, PRAM Battery: passo 8, imagem 1 %32
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
    Pergunte ao FixBot
    Comentar
  9. PowerBook G3 Pismo Processor Replacement: passo 9, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  10. PowerBook G3 Pismo Processor Replacement, Heat Sink: passo 10, imagem 1 %32
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    Pergunte ao FixBot
    Comentar
  11. PowerBook G3 Pismo Processor Replacement: passo 11, imagem 1 %32
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
    Pergunte ao FixBot
    Comentar
  12. PowerBook G3 Pismo Processor Replacement, Processor: passo 12, imagem 1 %32
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
    Pergunte ao FixBot
    Comentar
  13. PowerBook G3 Pismo Processor Replacement: passo 13, imagem 1 %32
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
1Comentário do guia
i know how to fix the processor but i have heard of much more powerful upgrades
Roman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 54
Ao todo: 9,824
