Ir para o conteúdo principal
PowerBook G3 Pismo Display Replacement
O que você precisa
  1. PowerBook G3 Pismo Display Replacement, Keyboard: passo 1, imagem 1 %32
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
    Pergunte ao FixBot
    Comentar
  2. PowerBook G3 Pismo Display Replacement: passo 2, imagem 1 %32
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
    Pergunte ao FixBot
    Comentar
  3. PowerBook G3 Pismo Display Replacement: passo 3, imagem 1 %32
    • Your laptop should look approximately like this.
    Pergunte ao FixBot
    Comentar
  4. PowerBook G3 Pismo Display Replacement, Heat Shield: passo 4, imagem 1 %32
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
    Pergunte ao FixBot
    Comentar
  5. PowerBook G3 Pismo Display Replacement: passo 5, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  6. PowerBook G3 Pismo Display Replacement, Airport Card: passo 6, imagem 1 %32
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
    Pergunte ao FixBot
    Comentar
  7. PowerBook G3 Pismo Display Replacement: passo 7, imagem 1 %32
    • Disconnect the antenna cable from the Airport card.
    Pergunte ao FixBot
    Comentar
  8. PowerBook G3 Pismo Display Replacement, PRAM Battery: passo 8, imagem 1 %32
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
    Pergunte ao FixBot
    Comentar
  9. PowerBook G3 Pismo Display Replacement: passo 9, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  10. PowerBook G3 Pismo Display Replacement, Heat Sink: passo 10, imagem 1 %32
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    Pergunte ao FixBot
    Comentar
  11. PowerBook G3 Pismo Display Replacement: passo 11, imagem 1 %32
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
    Pergunte ao FixBot
    Comentar
  12. PowerBook G3 Pismo Display Replacement, Processor: passo 12, imagem 1 %32
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
    Pergunte ao FixBot
    Comentar
  13. PowerBook G3 Pismo Display Replacement: passo 13, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  14. PowerBook G3 Pismo Display Replacement, Modem: passo 14, imagem 1 %32
    • Remove the black Torx screw from the right side of the modem.
    • Remove the small black plastic rectangle with four holes.
    Pergunte ao FixBot
    Comentar
  15. PowerBook G3 Pismo Display Replacement: passo 15, imagem 1 %32
    • Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
    Pergunte ao FixBot
    Comentar
  16. PowerBook G3 Pismo Display Replacement: passo 16, imagem 1 %32
    • Disconnect the cable from the right side of the modem.
    Pergunte ao FixBot
    Comentar
  17. PowerBook G3 Pismo Display Replacement, Hard Drive: passo 17, imagem 1 %32
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
    Pergunte ao FixBot
    Comentar
  18. PowerBook G3 Pismo Display Replacement: passo 18, imagem 1 %32
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
    Pergunte ao FixBot
    Comentar
  19. PowerBook G3 Pismo Display Replacement: passo 19, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  20. PowerBook G3 Pismo Display Replacement, Clutch Cover: passo 20, imagem 1 %32
    • Push the display back so that it lies flat.
    • Slip your index finger or a nylon tool under the clutch cover near the power button and pull gently upward until you feel it come free.
    • Repeat the previous step on the left side.
    Pergunte ao FixBot
    Comentar
  21. PowerBook G3 Pismo Display Replacement: passo 21, imagem 1 %32
    • Lift the clutch cover up and off, rotating it toward yourself.
    Pergunte ao FixBot
    Comentar
  22. PowerBook G3 Pismo Display Replacement, Inverter: passo 22, imagem 1 %32
    • Grasp the orange display data cable and disconnect it from the logic board.
    Pergunte ao FixBot
    Comentar
  23. PowerBook G3 Pismo Display Replacement: passo 23, imagem 1 %32
    • Remove the single black Torx screw that fastens the display cable to the plastic casing.
    • Grasp the thin display inverter board at its left end; lift up and rotate toward yourself.
    • There are two tabs that hold the display inverter in place; these are what you need to get past in order to pull the board free.
    Pergunte ao FixBot
    Comentar
  24. PowerBook G3 Pismo Display Replacement: passo 24, imagem 1 %32
    • Disconnect the white inverter cable from the right end of the board
    Pergunte ao FixBot
    Comentar
  25. PowerBook G3 Pismo Display Replacement: passo 25, imagem 1 %32
    • Disconnect the inverter plug, pulling directly up from the logic board.
    Pergunte ao FixBot
    Comentar
  26. PowerBook G3 Pismo Display Replacement, Display: passo 26, imagem 1 %32
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black Torx screws.
    Pergunte ao FixBot
    Comentar
  27. PowerBook G3 Pismo Display Replacement: passo 27, imagem 1 %32
    • Returning to the front, pull the black Airport antenna up from its recessed housing.
    Pergunte ao FixBot
    Comentar
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts.
    Pergunte ao FixBot
    Comentar
  28. PowerBook G3 Pismo Display Replacement: passo 29, imagem 1 %32
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
2Comentários do guia
just ruined a new screen and a Pismo. I'm a genius
Patricia Bonarrigo - Responder Compartilhar
This guide worked pretty well for getting the display out. However, I only have a replacement LCD screen, so now I'm scratching my head about how to actually open the removed display unit, and get at the insides so I can swap out the LCD panel. Will report back here if I find anything.
David Balatero - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 80
Ao todo: 15,817
