Ir para o conteúdo principal
PowerA Fusion Controller For Xbox One Motherboard Replacement
O que você precisa
  1. PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: passo 1, imagem 1 %32 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: passo 1, imagem 2 %32 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: passo 1, imagem 3 %32
    • Remove the nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Motherboard Replacement: passo 2, imagem 1 %32 PowerA Fusion Controller For Xbox One Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Motherboard Replacement: passo 3, imagem 1 %32 PowerA Fusion Controller For Xbox One Motherboard Replacement: passo 3, imagem 2 %32
    • Take off the glue that is on top of the soldered joints with a sprudger.
    • Desolder the soldered joints of the red and black wires that are connecting the vibration motors to the motherboard.
    • Remove the vibration motors and put them aside.
    • This guide will show how to solder and desolder connections.
  4. PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: passo 4, imagem 2 %32 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: passo 4, imagem 3 %32
    • Remove the five 9.2mm screws with a JIS #1 screwdriver. Indicated by the red circles.
    • Lift the motherboard and let it hang.
  5. PowerA Fusion Controller For Xbox One Motherboard Replacement: passo 5, imagem 1 %32 PowerA Fusion Controller For Xbox One Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the four 9.2mm screws that are holding the D-Pad to the controller housing. Indicated by the red circles.
    • Remove the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Andrea
Membro desde: 09/26/17
668 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S14-G4, Boczar Fall 2017 Membro de USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Membros
Autoria de 7 guias
1Comentário do guia
Hi I have a powera fusion controler model CPFA115315-02 and I took the controller apart to clean and I forgot how the lb rb button springs go, I look on the internet and couldn't find anything. Any help would be great
Thanks
Nhgamer - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 49
Ao todo: 3,581
