Ir para o conteúdo principal
Porter-Cable PCC710B Lever Assembly Replacement
O que você precisa
    1. Porter-Cable PCC710B Lever Assembly Replacement, Lever assembly: passo 1, imagem 1 %32
      • Place the tool on its side so the orange and white warning label barcodes are facing up.
      • The lever and battery base of the tool should point toward you.
      Pergunte ao FixBot
      Comentar
    2. Porter-Cable PCC710B Lever Assembly Replacement: passo 2, imagem 1 %32 Porter-Cable PCC710B Lever Assembly Replacement: passo 2, imagem 2 %32 Porter-Cable PCC710B Lever Assembly Replacement: passo 2, imagem 3 %32
      • Use a 5.5 mm nut driver to unscrew the Hex nut.
      • If the Hex nut is not unscrewing easily- you can use a 3 mm Hex head screwdriver to hold the other side of the screw still.
      Pergunte ao FixBot
      Comentar
    3. Porter-Cable PCC710B Lever Assembly Replacement: passo 3, imagem 1 %32
      • Flip the tool over and remove the black screw holding the tool together.
      • Get a good grip on the screw by using pliers to pull the screw out of the tool.
      Pergunte ao FixBot
      Comentar
    4. Porter-Cable PCC710B Lever Assembly Replacement: passo 4, imagem 1 %32 Porter-Cable PCC710B Lever Assembly Replacement: passo 4, imagem 2 %32 Porter-Cable PCC710B Lever Assembly Replacement: passo 4, imagem 3 %32
      • Pinch the lever with your fingers and pull it up and away from the tool. The lever pops right off! You can squeeze on the lever, and it will come off just as easily.
      • When replacing your new lever assembly, make sure the black torsion (the black staple-like hinge) is oriented correctly.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow instruction steps 3 to 1 in reverse order.
Alex Zapata
Membro desde: 09/19/22
665 Reputação
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 484
