Ir para o conteúdo principal
Portable Power Station Complete Disassembly
O que você precisa
  1. Portable Power Station Complete Disassembly, Shut down your power station: passo 1, imagem 1 %32 Portable Power Station Complete Disassembly, Shut down your power station: passo 1, imagem 2 %32 Portable Power Station Complete Disassembly, Shut down your power station: passo 1, imagem 3 %32
    • Let your Portable Power Station's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Hold down the blue action button for five seconds to shut down your power station.
    • Collapse the kickstand.
  2. Portable Power Station Complete Disassembly, Remove the rear cover screws: passo 2, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the rear cover screws: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    FixMat
    $36.95
    • Use a T10 Torx screwdriver to remove the two 8 mm‑long screws securing the rear cover.
  3. Portable Power Station Complete Disassembly, Remove the rear cover: passo 3, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the rear cover: passo 3, imagem 2 %32 Portable Power Station Complete Disassembly, Remove the rear cover: passo 3, imagem 3 %32
    • Grab the rear cover and pull the bottom edge towards you.
    • Remove the rear cover.
    • Don't try to remove the enclosure while the battery is still connected, or you'll damage the battery connector.
    • During reassembly, hook in the top edge of the rear cover first, then press the bottom edge into place.
  4. Portable Power Station Complete Disassembly, Pry up the battery connector: passo 4, imagem 1 %32 Portable Power Station Complete Disassembly, Pry up the battery connector: passo 4, imagem 2 %32
    • To avoid an electrical shock, don't use metal tools to disconnect the battery.
    • Insert the flat end of a spudger into one of the slots on either side of the battery connector. They're shaped just for this!
    • Use the spudger to begin prying up the connector.
    • If it's your first time disconnecting the battery, this may take some force.
  5. Portable Power Station Complete Disassembly: passo 5, imagem 1 %32 Portable Power Station Complete Disassembly: passo 5, imagem 2 %32 Portable Power Station Complete Disassembly: passo 5, imagem 3 %32
    • Repeat the process and pry up on alternating sides of the battery connector to "walk" it off of the two plugs, enough that you can easily grip it with your fingers.
    • You may have to reposition your spudger to fully release the battery connector. Be careful not to damage the board if you pry against it.
  6. Portable Power Station Complete Disassembly, Disconnect the battery: passo 6, imagem 1 %32 Portable Power Station Complete Disassembly, Disconnect the battery: passo 6, imagem 2 %32
    • Don't try to force the connector off or you might hurt yourself on the metal edges of the enclosure. If the connector doesn't come off easily, continue prying up with your spudger until the connector is loose enough to easily disconnect.
    • Grasp the battery connector by its edges and pull straight up to disconnect it.
  7. Portable Power Station Complete Disassembly, Reassembly information: passo 7, imagem 1 %32 Portable Power Station Complete Disassembly, Reassembly information: passo 7, imagem 2 %32 Portable Power Station Complete Disassembly, Reassembly information: passo 7, imagem 3 %32
    • During reassembly, follow these steps to reconnect the battery:
    • Tuck the wires behind the connector, so the side of the connector with positive (+) and negative (-) markings is facing outward.
    • Make sure the wires aren't pinched by the enclosure.
    • Align the connector over its two metal plugs so the negative (-) side is on the left of the USB‑C port and the positive (+) side is on the right.
    • Slide the connector onto its plugs and push down firmly until it's fully seated.
  8. Portable Power Station Complete Disassembly, Remove the chassis: passo 8, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the chassis: passo 8, imagem 2 %32
    • Place your fingers on the rear cover screw holes and push the chassis slightly out of the enclosure.
  9. Portable Power Station Complete Disassembly: passo 9, imagem 1 %32 Portable Power Station Complete Disassembly: passo 9, imagem 2 %32 Portable Power Station Complete Disassembly: passo 9, imagem 3 %32
    • Slide the chassis fully out of the enclosure, making sure the battery connector doesn't get snagged.
    • During reassembly:
    • Make sure the battery is disconnected before sliding the chassis into the enclosure. Otherwise, you'll damage the battery connector.
    • Insert the battery connector side of the chassis into the end of the enclosure closest to the kickstand and slide it into place.
  10. Portable Power Station Complete Disassembly, Remove the tool mount screws: passo 10, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the tool mount screws: passo 10, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 6 mm‑long screws securing the tool mounts on either side of the power station.
  11. Portable Power Station Complete Disassembly, Remove the tool mounts: passo 11, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the tool mounts: passo 11, imagem 2 %32
    • Use your fingers to pull the tool mounts off both sides of the power station.
    • The tool mounts are keyed. During reassembly, align the pins on the mounts with the holes in the enclosure.
  12. Portable Power Station Complete Disassembly, Remove the kickstand: passo 12, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the kickstand: passo 12, imagem 2 %32 Portable Power Station Complete Disassembly, Remove the kickstand: passo 12, imagem 3 %32
    • Be careful not to scratch the enclosure with the kickstand's metal arms. Before pulling on the kickstand, you may wish to put some tape over the enclosure below the kickstand bushing to prevent damage.
    • Grip the kickstand and pull one of the legs straight out of its bushing and away from the enclosure.
  13. Portable Power Station Complete Disassembly: passo 13, imagem 1 %32 Portable Power Station Complete Disassembly: passo 13, imagem 2 %32
    • Pull the other leg out of its bushing and remove the kickstand.
  14. Portable Power Station Complete Disassembly, Remove the metal battery cover: passo 14, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the metal battery cover: passo 14, imagem 2 %32
    • Use the flat end of a spudger or a clean fingernail to pry up the edge of the metal battery cover closest to the battery connector.
  15. Portable Power Station Complete Disassembly: passo 15, imagem 1 %32 Portable Power Station Complete Disassembly: passo 15, imagem 2 %32 Portable Power Station Complete Disassembly: passo 15, imagem 3 %32
    • The battery cover locks the battery in place. Once removed, the battery becomes free to fall out of the power station.
    • Remove the metal battery cover.
    • Hook the short edge of the cover without cutouts into place at the front, near the display.
    • Firmly press down on the opposite edge of the cover until it clips into place.
    • Make sure the battery cover doesn't pinch the battery cables—they should be routed under the cover and angled inward.
  16. Portable Power Station Complete Disassembly, Remove the battery: passo 16, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the battery: passo 16, imagem 2 %32 Portable Power Station Complete Disassembly, Remove the battery: passo 16, imagem 3 %32
    • Remove the battery.
    • During reassembly, don't reconnect the battery until after the enclosure is installed, or you'll damage the battery connector when everything goes back together.
  17. Portable Power Station Complete Disassembly, Remove the selector knob: passo 17, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the selector knob: passo 17, imagem 2 %32 Portable Power Station Complete Disassembly, Remove the selector knob: passo 17, imagem 3 %32
    • Pull the silver selector knob directly away from the front panel to remove it.
  18. Portable Power Station Complete Disassembly, Remove the front panel: passo 18, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the front panel: passo 18, imagem 2 %32 Portable Power Station Complete Disassembly, Remove the front panel: passo 18, imagem 3 %32
    • Use your fingers to depress the two locking tabs holding the front panel in place.
    • Press on the clips themselves (just behind the front panel) and not through the cutouts on the top edge of the front panel.
    • While pressing the tabs down, push the front panel away from the chassis and remove it.
    • Hook in the bottom edge of the front panel first, then push the top edge until it clicks into place.
    • Make sure the two USB-C ports slide into their cutouts in the front panel and aren't trapped underneath.
  19. Portable Power Station Complete Disassembly, Remove the main board supports: passo 19, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the main board supports: passo 19, imagem 2 %32 Portable Power Station Complete Disassembly, Remove the main board supports: passo 19, imagem 3 %32
    • Flip your power station over.
    • Use a Phillips screwdriver to remove the four 6 mm‑long screws securing the two main board supports.
    • Hold the supports in place while removing the final screws. Otherwise, the support may swing onto the board and damage the small, surface‑mounted components.
    • Remove the main board supports.
    • During reassembly, make sure the beveled sides of the main board support screw holes face up.
  20. Portable Power Station Complete Disassembly, Remove the chassis: passo 20, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the chassis: passo 20, imagem 2 %32 Portable Power Station Complete Disassembly, Remove the chassis: passo 20, imagem 3 %32
    • Use your finger to gently lift the main board by the USB‑C port, enough that you can grip the board's edges.
  21. Portable Power Station Complete Disassembly: passo 21, imagem 1 %32 Portable Power Station Complete Disassembly: passo 21, imagem 2 %32 Portable Power Station Complete Disassembly: passo 21, imagem 3 %32
    • With one hand, firmly secure the chassis.
    • With your free hand, grip the main board near the center.
    • Lift the board straight up and pull it away from the display to remove it, threading the selector knob through its cutout.
  22. Portable Power Station Complete Disassembly, Remove the UI board: passo 22, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the UI board: passo 22, imagem 2 %32 Portable Power Station Complete Disassembly, Remove the UI board: passo 22, imagem 3 %32
    • Long pins on the main board plug into the UI board and hold it in place.
    • With one hand, hold on to the main board.
    • Don't press the board down against your work surface, or you may damage the surface‑mounted components on the board.
    • With your free hand, grip the UI board by its edges and firmly pull it straight away from the main board to disconnect it.
    • Make sure the boards stay perpendicular to each other or the pins might get damaged.
    • When pushing the UI board back into place, make sure the side opposite the sockets goes into its cutout on the main board. Otherwise, it will prevent the UI board from fully seating.
  23. Portable Power Station Complete Disassembly, Remove the selector knob: passo 23, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the selector knob: passo 23, imagem 2 %32
    • Use your fingers, small pliers, or a 10 mm wrench to loosen the thin nut securing the selector knob.
    • If you're using pliers or a wrench, be careful not to scrape the display or the board.
  24. Portable Power Station Complete Disassembly: passo 24, imagem 1 %32 Portable Power Station Complete Disassembly: passo 24, imagem 2 %32 Portable Power Station Complete Disassembly: passo 24, imagem 3 %32
    • Pull the nut and its washer off the front of the knob and remove them.
    • Pull the knob out of its cutout to free it from the UI board.
    • The selector knob assembly is still attached to the UI board by its cables.
    • Hold the knob and its cables out of the way as necessary while working on the UI board.
  25. Portable Power Station Complete Disassembly, Disconnect the display: passo 25, imagem 1 %32 Portable Power Station Complete Disassembly, Disconnect the display: passo 25, imagem 2 %32
    • Be very careful not to damage any of the small, surface‑mounted components near the connector.
    • Use the point of a spudger to flip up the locking flap on the display cable ZIF connector.
  26. Portable Power Station Complete Disassembly: passo 26, imagem 1 %32 Portable Power Station Complete Disassembly: passo 26, imagem 2 %32
    • Use angled tweezers to grip the display cable and gently pull it straight out of the socket.
    • During reassembly, use your finger to carefully slide the cable back into the socket.
  27. Portable Power Station Complete Disassembly, Remove the display: passo 27, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the display: passo 27, imagem 2 %32 Portable Power Station Complete Disassembly, Remove the display: passo 27, imagem 3 %32
    • Be careful not to damage any of the small, surface‑mounted components on the board.
    • Hold the UI board slightly above your work surface and use the flat side of a spudger to firmly push the two display pegs through their cutouts on the board.
    • This is tricky and might require multiple attempts. Alternatively, you can use blunt‑nose tweezers to squeeze the pegs together to release them.
    • During reassembly, push the pegs into their holes on the UI board until they click into place.
  28. Portable Power Station Complete Disassembly: passo 28, imagem 1 %32 Portable Power Station Complete Disassembly: passo 28, imagem 2 %32
    • Remove the display.
    • During reassembly, make sure to thread the display cable through its cutout on the UI board.
  29. Portable Power Station Complete Disassembly, Remove the action button: passo 29, imagem 1 %32 Portable Power Station Complete Disassembly, Remove the action button: passo 29, imagem 2 %32 Portable Power Station Complete Disassembly, Remove the action button: passo 29, imagem 3 %32
    • Use the point of a spudger to press the exposed blue clip on the top of the action button.
    • Remove the action button.
  30. Portable Power Station Complete Disassembly, Full disassembly: passo 30, imagem 1 %32
    • Your Portable Power Station is fully disassembled!
Conclusão
To reassemble your Portable Power Station, follow these instructions in reverse order.
Remember to calibrate your battery after reassembly if the battery health or capacity seem incorrect.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Documentos anexados
Nick Schultz
Membro desde: 03/24/24
15.772 Reputação
Autoria de 87 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.415 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 69
Duração total: 451
