Ir para o conteúdo principal
Portable Power Station Battery Replacement
O que você precisa
  1. Portable Power Station Battery Replacement, Shut down your power station: passo 1, imagem 1 %32 Portable Power Station Battery Replacement, Shut down your power station: passo 1, imagem 2 %32 Portable Power Station Battery Replacement, Shut down your power station: passo 1, imagem 3 %32
    • Let your Portable Power Station's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Hold down the blue action button for five seconds to shut down your power station.
    • Collapse the kickstand.
  2. Portable Power Station Battery Replacement, Remove the rear cover screws: passo 2, imagem 1 %32 Portable Power Station Battery Replacement, Remove the rear cover screws: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    FixMat
    $31.41
    • Use a T10 Torx screwdriver to remove the two 8 mm‑long screws securing the rear cover.
  3. Portable Power Station Battery Replacement, Remove the rear cover: passo 3, imagem 1 %32 Portable Power Station Battery Replacement, Remove the rear cover: passo 3, imagem 2 %32 Portable Power Station Battery Replacement, Remove the rear cover: passo 3, imagem 3 %32
    • Grab the rear cover and pull the bottom edge towards you.
    • Remove the rear cover.
    • Don't try to remove the enclosure while the battery is still connected, or you'll damage the battery connector.
    • During reassembly, hook in the top edge of the rear cover first, then press the bottom edge into place.
  4. Portable Power Station Battery Replacement, Pry up the battery connector: passo 4, imagem 1 %32 Portable Power Station Battery Replacement, Pry up the battery connector: passo 4, imagem 2 %32
    • To avoid an electrical shock, don't use metal tools to disconnect the battery.
    • Insert the flat end of a spudger into one of the slots on either side of the battery connector. They're shaped just for this!
    • Use the spudger to begin prying up the connector.
    • If it's your first time disconnecting the battery, this may take some force.
  5. Portable Power Station Battery Replacement: passo 5, imagem 1 %32 Portable Power Station Battery Replacement: passo 5, imagem 2 %32 Portable Power Station Battery Replacement: passo 5, imagem 3 %32
    • Repeat the process and pry up on alternating sides of the battery connector to "walk" it off of the two plugs, enough that you can easily grip it with your fingers.
    • You may have to reposition your spudger to fully release the battery connector. Be careful not to damage the board if you pry against it.
  6. Portable Power Station Battery Replacement, Disconnect the battery: passo 6, imagem 1 %32 Portable Power Station Battery Replacement, Disconnect the battery: passo 6, imagem 2 %32
    • Don't try to force the connector off or you might hurt yourself on the metal edges of the enclosure. If the connector doesn't come off easily, continue prying up with your spudger until the connector is loose enough to easily disconnect.
    • Grasp the battery connector by its edges and pull straight up to disconnect it.
  7. Portable Power Station Battery Replacement, Reassembly information: passo 7, imagem 1 %32 Portable Power Station Battery Replacement, Reassembly information: passo 7, imagem 2 %32 Portable Power Station Battery Replacement, Reassembly information: passo 7, imagem 3 %32
    • During reassembly, follow these steps to reconnect the battery:
    • Tuck the wires behind the connector, so the side of the connector with positive (+) and negative (-) markings is facing outward.
    • Make sure the wires aren't pinched by the enclosure.
    • Align the connector over its two metal plugs so the negative (-) side is on the left of the USB‑C port and the positive (+) side is on the right.
    • Slide the connector onto its plugs and push down firmly until it's fully seated.
  8. Portable Power Station Battery Replacement, Remove the chassis: passo 8, imagem 1 %32 Portable Power Station Battery Replacement, Remove the chassis: passo 8, imagem 2 %32
    • Place your fingers on the rear cover screw holes and push the chassis slightly out of the enclosure.
  9. Portable Power Station Battery Replacement: passo 9, imagem 1 %32 Portable Power Station Battery Replacement: passo 9, imagem 2 %32 Portable Power Station Battery Replacement: passo 9, imagem 3 %32
    • Slide the chassis fully out of the enclosure, making sure the battery connector doesn't get snagged.
    • During reassembly:
    • Make sure the battery is disconnected before sliding the chassis into the enclosure. Otherwise, you'll damage the battery connector.
    • Insert the battery connector side of the chassis into the end of the enclosure closest to the kickstand and slide it into place.
  10. Portable Power Station Battery Replacement, Remove the metal battery cover: passo 10, imagem 1 %32 Portable Power Station Battery Replacement, Remove the metal battery cover: passo 10, imagem 2 %32
    • Use the flat end of a spudger or a clean fingernail to pry up the edge of the metal battery cover closest to the battery connector.
  11. Portable Power Station Battery Replacement: passo 11, imagem 1 %32 Portable Power Station Battery Replacement: passo 11, imagem 2 %32 Portable Power Station Battery Replacement: passo 11, imagem 3 %32
    • The battery cover locks the battery in place. Once removed, the battery becomes free to fall out of the power station.
    • Remove the metal battery cover.
    • Hook the short edge of the cover without cutouts into place at the front, near the display.
    • Firmly press down on the opposite edge of the cover until it clips into place.
    • Make sure the battery cover doesn't pinch the battery cables—they should be routed under the cover and angled inward.
  12. Portable Power Station Battery Replacement, Remove the battery: passo 12, imagem 1 %32 Portable Power Station Battery Replacement, Remove the battery: passo 12, imagem 2 %32 Portable Power Station Battery Replacement, Remove the battery: passo 12, imagem 3 %32
    • Remove the battery.
    • During reassembly, don't reconnect the battery until after the enclosure is installed, or you'll damage the battery connector when everything goes back together.
Conclusão
To reassemble your Portable Power Station, follow these instructions in reverse order.
Calibrate your newly installed battery after completing this guide.
4 outras pessoas executaram este guia.
Nick Schultz
Membro desde: 03/24/24
37.233 Reputação
Autoria de 226 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.623 guias
2Comentários do guia
I'm genuinely baffled iFixit doesn't have replacements for it's own product on stock. That made me take a huge step back while investigating the FixHub.
Adri - Responder
Adri, we're working to restock batteries. Feel free to use the Notify Me button to get updated when they're back in stock. We do have various other FixHub parts in stock: All Parts
Carsten Frauenheim -
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 33
Últimos 30 dias: 170
Ao todo: 2,394
