Ir para o conteúdo principal
Polaroid Flash Unit Shell Replacement
O que você precisa
  1. Polaroid Flash Unit Shell Replacement, Before you begin: passo 1, imagem 1 %32
    • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
    • Unplug all cables from your camera.
    Pergunte ao FixBot
    Comentar
  2. Polaroid Flash Unit Shell Replacement, Open your camera: passo 2, imagem 1 %32 Polaroid Flash Unit Shell Replacement, Open your camera: passo 2, imagem 2 %32
    • Fully open the flash unit at the front of your camera.
    Pergunte ao FixBot
    Comentar
  3. Polaroid Flash Unit Shell Replacement, Remove the screw cover: passo 3, imagem 1 %32 Polaroid Flash Unit Shell Replacement, Remove the screw cover: passo 3, imagem 2 %32 Polaroid Flash Unit Shell Replacement, Remove the screw cover: passo 3, imagem 3 %32
    • Slide the tip of an opening pick under the right edge of the screw cover, near the flash.
    • Leave the pick inserted under the cover for the next step.
    Pergunte ao FixBot
    Comentar
  4. Polaroid Flash Unit Shell Replacement: passo 4, imagem 1 %32 Polaroid Flash Unit Shell Replacement: passo 4, imagem 2 %32 Polaroid Flash Unit Shell Replacement: passo 4, imagem 3 %32
    • Slide the cover towards the flash to release the clips securing it.
    • Your pick might fall out—that's fine.
    • Pull the cover straight away from the camera and remove it.
    Pergunte ao FixBot
    Comentar
  5. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: passo 5, imagem 1 %32 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: passo 5, imagem 2 %32 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: passo 5, imagem 3 %32
    • Hold the flash unit open with one hand.
    • With your free hand, use a Phillips screwdriver to remove the three 5.9 mm‑long screws securing the flash unit shell.
    Pergunte ao FixBot
    Comentar
  6. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: passo 6, imagem 1 %32 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: passo 6, imagem 2 %32 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: passo 6, imagem 3 %32
    • Fully close the flash unit for a better grip on the shell.
    • Secure the camera with one hand, and firmly grip the flash unit shell with the other.
    • Lift the right edge of the shell (the side closest to the charging port) to release the clips securing it.
    • You should feel and hear "clicks" as the clips release.
    • Pull the shell up and away from the camera to remove it.
    • During reassembly, put the shell in place and push down firmly to engage the clips.
    Pergunte ao FixBot
    Comentar
Conclusão
Spencer Day
Membro desde: 09/14/22
194.728 Reputação
Autoria de 1.243 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.572 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 383
