Introdução
This Polaroid A10 Front/Back Camera Replacement guide might be needed if either your front, back, or both camera lenses are damaged, shattered, and/or scratched. If only one of your camera lenses are damaged, you will be replacing both front and back cameras because they are both contained in a single component. To acquire further information regarding the Polaroid A10 front/back camera replacement, follow this efficient guide to escort you through the replacement procedures.
O que você precisa
Begin by having the side with volume and power button face up towards you.
Insert a plastic opening tool between the display and the back cover.
Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
Ferramenta utilizada neste passo:Plastic Cards$2.99
Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
Gently lift up the battery as you continue to separate the glue from the battery.
Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
The camera head is located on the upper middle section of the device, close to the battery.
