Introdução
Use this guide to replace a worn-out or dead battery in your Xiaomi Pocophone F1.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
O que você precisa
Before you begin, switch off your phone.
Insert a SIM eject tool or a paperclip into the small hole on the SIM card tray on the left edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Remove the two 2.7 mm-long Torx T3 screws from the bottom edge of your phone.
Insert an opening tool between the screen and the back cover at the bottom edge of the screen.
Slide the opening tool to the bottom right corner to release the plastic clips holding the back cover in place.
Slide the opening tool around the bottom right corner.
Slide the opening tool along the right edge of the Pocophone F1 to release the plastic clips.
Use the flat end of a spudger to pry up and disconnect the fingerprint flex connector.
Remove the back cover.
Use the flat end of a spudger to pry up and disconnect the battery connector.
Use the flat end of a spudger to pry up and disconnect the interconnect flex cable.
Fold the interconnect flex cable out of your way in order to get access to the battery.
Grab both ends of the orange sticker.
Pull both ends of the orange sticker straight up to lift the battery out of its recess.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery.
26 outras pessoas executaram este guia.
13 comentários
I need advice wich battery to buy and from where.
I can't find a genuine or at least good replacement battery online.
Non of them have a working temperature sensor and most have a lower capacity than advertised.
Xiaomi isn't selling batteries directly to customers in germany.
Did you find any reliable alternative? Having the same problem at the moment. Thinking about going to one of those repair Shops but actually they probably use the same batteries, that I am finding online.
Thanks for the awesome guide!
I also am not sure about where to get a genuine battery from
