Ir para o conteúdo principal
PlayStation 5 LED Board Replacement
O que você precisa
  1. PlayStation 5 LED Board Replacement, Remove the stand screw: passo 1, imagem 1 %32
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
    Pergunte ao FixBot
    Comentar
  2. PlayStation 5 LED Board Replacement, Remove the vertical stand: passo 2, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the vertical stand: passo 2, imagem 2 %32
    • Lift straight up to remove the stand.
    Pergunte ao FixBot
    Comentar
  3. PlayStation 5 LED Board Replacement, Store the stand screw: passo 3, imagem 1 %32 PlayStation 5 LED Board Replacement, Store the stand screw: passo 3, imagem 2 %32
    • Insert the screw into the cubby on the bottom of the stand.
    Pergunte ao FixBot
    Comentar
  4. PlayStation 5 LED Board Replacement, Cap the screw hole: passo 4, imagem 1 %32 PlayStation 5 LED Board Replacement, Cap the screw hole: passo 4, imagem 2 %32 PlayStation 5 LED Board Replacement, Cap the screw hole: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
    Pergunte ao FixBot
    Comentar
  5. PlayStation 5 LED Board Replacement, Close the cubby: passo 5, imagem 1 %32 PlayStation 5 LED Board Replacement, Close the cubby: passo 5, imagem 2 %32 PlayStation 5 LED Board Replacement, Close the cubby: passo 5, imagem 3 %32
    • Twist the stand counterclockwise to close the cubby.
    Pergunte ao FixBot
    Comentar
  6. PlayStation 5 LED Board Replacement, Remove the horizontal stand: passo 6, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the horizontal stand: passo 6, imagem 2 %32
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
    Pergunte ao FixBot
    Comentar
  7. PlayStation 5 LED Board Replacement, Remove the right faceplate: passo 7, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the right faceplate: passo 7, imagem 2 %32 PlayStation 5 LED Board Replacement, Remove the right faceplate: passo 7, imagem 3 %32
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
    Pergunte ao FixBot
    Comentar
  8. PlayStation 5 LED Board Replacement: passo 8, imagem 1 %32 PlayStation 5 LED Board Replacement: passo 8, imagem 2 %32
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
    Pergunte ao FixBot
    Comentar
  9. PlayStation 5 LED Board Replacement, Pry up the grille: passo 9, imagem 1 %32 PlayStation 5 LED Board Replacement, Pry up the grille: passo 9, imagem 2 %32 PlayStation 5 LED Board Replacement, Pry up the grille: passo 9, imagem 3 %32
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
    Pergunte ao FixBot
    Comentar
  10. PlayStation 5 LED Board Replacement, Remove the grille: passo 10, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the grille: passo 10, imagem 2 %32
    • Lift the grille away from the case to remove it.
    Pergunte ao FixBot
    Comentar
  11. PlayStation 5 LED Board Replacement, Remove the fan shroud screws: passo 11, imagem 1 %32
    Magnetic Project Mat
    $19.95
    • Use a TR9 Torx Security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    Pergunte ao FixBot
    Comentar
  12. PlayStation 5 LED Board Replacement, Remove the fan shroud: passo 12, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the fan shroud: passo 12, imagem 2 %32
    • Lift the fan shroud straight up to remove it.
    Pergunte ao FixBot
    Comentar
  13. PlayStation 5 LED Board Replacement, Remove the wire cover: passo 13, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the wire cover: passo 13, imagem 2 %32 PlayStation 5 LED Board Replacement, Remove the wire cover: passo 13, imagem 3 %32
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
    Pergunte ao FixBot
    Comentar
  14. PlayStation 5 LED Board Replacement: passo 14, imagem 1 %32 PlayStation 5 LED Board Replacement: passo 14, imagem 2 %32 PlayStation 5 LED Board Replacement: passo 14, imagem 3 %32
    • Use your fingers to peel off the wire cover.
    Pergunte ao FixBot
    Comentar
  15. PlayStation 5 LED Board Replacement, Disconnect the fan: passo 15, imagem 1 %32 PlayStation 5 LED Board Replacement, Disconnect the fan: passo 15, imagem 2 %32
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
    Pergunte ao FixBot
    Comentar
  16. PlayStation 5 LED Board Replacement, Remove the fan: passo 16, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the fan: passo 16, imagem 2 %32 PlayStation 5 LED Board Replacement, Remove the fan: passo 16, imagem 3 %32
    • Lift the fan up and out of the case to remove it.
    Pergunte ao FixBot
    Comentar
  17. PlayStation 5 LED Board Replacement, Remove the SSD cover: passo 17, imagem 1 %32
    • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
    Pergunte ao FixBot
    Comentar
  18. PlayStation 5 LED Board Replacement: passo 18, imagem 1 %32 PlayStation 5 LED Board Replacement: passo 18, imagem 2 %32 PlayStation 5 LED Board Replacement: passo 18, imagem 3 %32
    • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
    • Remove the SSD cover.
    Pergunte ao FixBot
    Comentar
  19. PlayStation 5 LED Board Replacement, Remove the optical drive wire: passo 19, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the optical drive wire: passo 19, imagem 2 %32
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
    Pergunte ao FixBot
    Comentar
  20. PlayStation 5 LED Board Replacement: passo 20, imagem 1 %32 PlayStation 5 LED Board Replacement: passo 20, imagem 2 %32
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
    Pergunte ao FixBot
    Comentar
  21. PlayStation 5 LED Board Replacement, Remove the tamper-evident sticker: passo 21, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the tamper-evident sticker: passo 21, imagem 2 %32 PlayStation 5 LED Board Replacement, Remove the tamper-evident sticker: passo 21, imagem 3 %32
    • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
    • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
    • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
    Pergunte ao FixBot
    Comentar
  22. PlayStation 5 LED Board Replacement, Remove the case screws: passo 22, imagem 1 %32
    • Use a TR8 Torx Security driver to remove the eleven screws securing the case:
    • Six 18.6 mm-long screws
    • Two 43.2 mm-long screws
    • One 7.3 mm-long screw
    Pergunte ao FixBot
    Comentar
  23. PlayStation 5 LED Board Replacement, Remove the case: passo 23, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the case: passo 23, imagem 2 %32
    • Lift the case straight up to remove it.
    Pergunte ao FixBot
    Comentar
  24. PlayStation 5 LED Board Replacement, Remove the optical drive ribbon cable: passo 24, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the optical drive ribbon cable: passo 24, imagem 2 %32 PlayStation 5 LED Board Replacement, Remove the optical drive ribbon cable: passo 24, imagem 3 %32
    • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
    • Pull only on the pull tab, not the cable itself.
    Pergunte ao FixBot
    Comentar
  25. PlayStation 5 LED Board Replacement, Remove the optical drive: passo 25, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the optical drive: passo 25, imagem 2 %32
    • Lift the optical drive away from the device to remove it.
    Pergunte ao FixBot
    Comentar
  26. PlayStation 5 LED Board Replacement, Remove the optical drive ribbon cable: passo 26, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the optical drive ribbon cable: passo 26, imagem 2 %32 PlayStation 5 LED Board Replacement, Remove the optical drive ribbon cable: passo 26, imagem 3 %32
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  27. PlayStation 5 LED Board Replacement, Remove the power and eject button ribbon cable: passo 27, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the power and eject button ribbon cable: passo 27, imagem 2 %32
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
    Pergunte ao FixBot
    Comentar
  28. PlayStation 5 LED Board Replacement, Remove the LED ribbon cable: passo 28, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the LED ribbon cable: passo 28, imagem 2 %32
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
    Pergunte ao FixBot
    Comentar
  29. PlayStation 5 LED Board Replacement, Remove the antenna wires: passo 29, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the antenna wires: passo 29, imagem 2 %32 PlayStation 5 LED Board Replacement, Remove the antenna wires: passo 29, imagem 3 %32
    • Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
    • Lift the wire's connector straight up to disconnect it from the motherboard.
    • Repeat for the black Wi-Fi antenna wire.
    • Some board revisions may not have these antenna wires. If your board is missing these connectors, skip this step.
    Pergunte ao FixBot
    Comentar
  30. PlayStation 5 LED Board Replacement: passo 30, imagem 1 %32 PlayStation 5 LED Board Replacement: passo 30, imagem 2 %32 PlayStation 5 LED Board Replacement: passo 30, imagem 3 %32
    • Use a pair of tweezers to grip the black or blue power supply antenna wire at its metal base, as close to the connector as possible.
    • Repeat for the white power supply antenna wire.
    Pergunte ao FixBot
    Comentar
  31. PlayStation 5 LED Board Replacement, Remove the white stickers: passo 31, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the white stickers: passo 31, imagem 2 %32 PlayStation 5 LED Board Replacement, Remove the white stickers: passo 31, imagem 3 %32
    • Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
    • Remove the antenna wires from underneath the sticker.
    • Press the white sticker back down onto the top shield plate so it can be reused.
    Pergunte ao FixBot
    Comentar
  32. PlayStation 5 LED Board Replacement: passo 32, imagem 1 %32 PlayStation 5 LED Board Replacement: passo 32, imagem 2 %32 PlayStation 5 LED Board Replacement: passo 32, imagem 3 %32
    • Repeat the previous step to peel back the four remaining stickers.
    Pergunte ao FixBot
    Comentar
  33. PlayStation 5 LED Board Replacement: passo 33, imagem 1 %32 PlayStation 5 LED Board Replacement: passo 33, imagem 2 %32 PlayStation 5 LED Board Replacement: passo 33, imagem 3 %32
    • Use a pair of tweezers to peel back the white sticker holding the LED ribbon cable to the heat sink.
    • Remove the LED ribbon cable from underneath the sticker.
    • Press the white sticker back down onto the heat sink so it can be reused.
    Pergunte ao FixBot
    Comentar
  34. PlayStation 5 LED Board Replacement, Remove the top shield plate screws: passo 34, imagem 1 %32
    • Use a TR8 Torx Security driver to remove the forty-two screws securing the top shield plate:
    • Forty-one 7.3 mm-long screws
    • One 43.2 mm-long screw
    Pergunte ao FixBot
    Comentar
  35. PlayStation 5 LED Board Replacement, Remove the top shield plate: passo 35, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the top shield plate: passo 35, imagem 2 %32 PlayStation 5 LED Board Replacement, Remove the top shield plate: passo 35, imagem 3 %32
    • Lift the top shield plate off of the motherboard to remove it.
    • During reassembly, this is a good point to replace any thermal pads on the top of the main board, if necessary. The pads may be stuck to both the top shield plate and the main board.
    • It's important that the replacement pads are the same thickness as the originals, otherwise the foam around the APU may not seal properly.
    Pergunte ao FixBot
    Comentar
  36. PlayStation 5 LED Board Replacement, Disconnect the USB board: passo 36, imagem 1 %32 PlayStation 5 LED Board Replacement, Disconnect the USB board: passo 36, imagem 2 %32 PlayStation 5 LED Board Replacement, Disconnect the USB board: passo 36, imagem 3 %32
    • Use your finger to depress the metal locking tab on the USB board cable's board connector.
    • With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
    Pergunte ao FixBot
    Comentar
  37. PlayStation 5 LED Board Replacement, Remove the left faceplate: passo 37, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the left faceplate: passo 37, imagem 2 %32 PlayStation 5 LED Board Replacement, Remove the left faceplate: passo 37, imagem 3 %32
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
    Pergunte ao FixBot
    Comentar
  38. PlayStation 5 LED Board Replacement: passo 38, imagem 1 %32 PlayStation 5 LED Board Replacement: passo 38, imagem 2 %32
    • Remove the left faceplate.
    Pergunte ao FixBot
    Comentar
  39. PlayStation 5 LED Board Replacement, Remove the screws: passo 39, imagem 1 %32
    • Use a TR8 Torx Security driver to remove the two 29.4 mm-long screws securing the case to the motherboard and heat sink assembly.
    Pergunte ao FixBot
    Comentar
  40. PlayStation 5 LED Board Replacement, Remove the case: passo 40, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the case: passo 40, imagem 2 %32 PlayStation 5 LED Board Replacement, Remove the case: passo 40, imagem 3 %32
    • Lift the front edge of the case off of the motherboard and heat sink assembly.
    • With the front edge elevated, push the case back, away from the motherboard and heat sink assembly, to maneuver the charging port out of its slot in the case.
    • Remove the case.
    • The front plate may come apart from the plastic case. During reassembly, make sure the front plate is in place before reinserting the motherboard and power supply.
    Pergunte ao FixBot
    Comentar
  41. PlayStation 5 LED Board Replacement, Remove the middle panel: passo 41, imagem 1 %32 PlayStation 5 LED Board Replacement, Remove the middle panel: passo 41, imagem 2 %32
    • Lift up to remove the middle panel from the case.
    Pergunte ao FixBot
    Comentar
  42. PlayStation 5 LED Board Replacement, Disconnect the LED ribbon cable: passo 42, imagem 1 %32 PlayStation 5 LED Board Replacement, Disconnect the LED ribbon cable: passo 42, imagem 2 %32
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED board ribbon cable.
    Pergunte ao FixBot
    Comentar
  43. PlayStation 5 LED Board Replacement, Remove the LED board screw: passo 43, imagem 1 %32
    • Use a Phillips screwdriver to remove the 6.5 mm-long screw securing the LED board to the middle panel.
    Pergunte ao FixBot
    Comentar
  44. PlayStation 5 LED Board Replacement: passo 44, imagem 1 %32 PlayStation 5 LED Board Replacement: passo 44, imagem 2 %32
    • Remove the LED board.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
7 outras pessoas executaram este guia.
Robert Boyd
Membro desde: 02/01/21
33.336 Reputação
Autoria de 94 guias
4Comentários do guia
where can I buy a replacement light board?
rot253 - Responder Compartilhar
If you are in the UK, they are sold here:
https://consoletherapy.com/store/genuine...
James H - Responder Compartilhar
Hello. I have damaged the original console backlight. Can I replace it? Can I buy a ready-made original element?
SauroN - Responder Compartilhar
Do i have to buy new parts for this, of it's where can i buy them
Federico Cocito - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 27
Últimos 7 dias: 140
Últimos 30 dias: 722
Ao todo: 19,384
