Ir para o conteúdo principal
PlayStation 4 Pro Optical Drive Replacement
O que você precisa
  1. PlayStation 4 Pro Optical Drive Replacement, Hard Drive Caddy: passo 1, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement, Hard Drive Caddy: passo 1, imagem 2 %32 PlayStation 4 Pro Optical Drive Replacement, Hard Drive Caddy: passo 1, imagem 3 %32
    • Flip the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
    Pergunte ao FixBot
    Comentar
  2. PlayStation 4 Pro Optical Drive Replacement: passo 2, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 Screwdriver to remove the single screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
    Pergunte ao FixBot
    Comentar
  3. PlayStation 4 Pro Optical Drive Replacement, Power Supply Assembly: passo 3, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement, Power Supply Assembly: passo 3, imagem 2 %32 PlayStation 4 Pro Optical Drive Replacement, Power Supply Assembly: passo 3, imagem 3 %32
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
    Pergunte ao FixBot
    Comentar
  4. PlayStation 4 Pro Optical Drive Replacement: passo 4, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement: passo 4, imagem 2 %32 PlayStation 4 Pro Optical Drive Replacement: passo 4, imagem 3 %32
    • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
    • Two 31mm screws.
    • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
    • Remove the metal plate by pulling it up.
    Pergunte ao FixBot
    Comentar
  5. PlayStation 4 Pro Optical Drive Replacement: passo 5, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement: passo 5, imagem 2 %32 PlayStation 4 Pro Optical Drive Replacement: passo 5, imagem 3 %32
    • Flip the console over so the bottom is facing up.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left.
    • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
    Pergunte ao FixBot
    Comentar
  6. PlayStation 4 Pro Optical Drive Replacement: passo 6, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement: passo 6, imagem 2 %32 PlayStation 4 Pro Optical Drive Replacement: passo 6, imagem 3 %32
    • Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate.
    • Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate.
    • 7200-series models have 13 additional 4mm screws around the top and right of the metal plate. These screws are are indicated with a triangle. This may apply to other models.
    • Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
    Pergunte ao FixBot
    Comentar
  7. PlayStation 4 Pro Optical Drive Replacement: passo 7, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement: passo 7, imagem 2 %32
    • Pull the white fan connector straight out of the yellow mount on the motherboard.
    Pergunte ao FixBot
    Comentar
  8. PlayStation 4 Pro Optical Drive Replacement: passo 8, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement: passo 8, imagem 2 %32
    • Pull out the five small, blue low profile cables connected to the metal plate.
    • Lift the retaining flap on the ZIF connector of the large ribbon cable.
    • Pull the large ribbon cable from its socket.
    • Do not pull on the biggest blue cable without lifting the tab first. Doing so can damage the connection.
    Pergunte ao FixBot
    Comentar
  9. PlayStation 4 Pro Optical Drive Replacement: passo 9, imagem 1 %32
    • Pull up and remove the metal plate.
    Pergunte ao FixBot
    Comentar
  10. PlayStation 4 Pro Optical Drive Replacement: passo 10, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement: passo 10, imagem 2 %32 PlayStation 4 Pro Optical Drive Replacement: passo 10, imagem 3 %32
    • Flip the console over to continue working on the top side.
    • Pull up on the power supply unit and set it on the console.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
    Pergunte ao FixBot
    Comentar
  11. PlayStation 4 Pro Optical Drive Replacement, Motherboard: passo 11, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement, Motherboard: passo 11, imagem 2 %32 PlayStation 4 Pro Optical Drive Replacement, Motherboard: passo 11, imagem 3 %32
    • If you are working on the 7200-series model, this metal plate will have been already removed as part of the removing the larger motherboard plate. You may skip this step if this is the case.
    • Carefully flip the console over so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the eight 4mm screws on the metal plate with the X-like symbol.
    • Use a plastic opening tool to remove the metal plate with the X-like shape.
    Pergunte ao FixBot
    Comentar
  12. PlayStation 4 Pro Optical Drive Replacement: passo 12, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement: passo 12, imagem 2 %32 PlayStation 4 Pro Optical Drive Replacement: passo 12, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the four 13mm screws on the X-shaped metal plate underneath.
    • For 7200-series models this is instead a S-shaped metal plate with 2 screws.
    • Grip the X-shaped retaining bracket and lift straight up.
    Pergunte ao FixBot
    Comentar
  13. PlayStation 4 Pro Optical Drive Replacement: passo 13, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement: passo 13, imagem 2 %32
    • Grip the edge of the motherboard and slowly lift upwards to remove it from the device.
    • For reassembly, use this guide to reapply thermal paste between the motherboard and the metal plate underneath.
    Pergunte ao FixBot
    Comentar
  14. PlayStation 4 Pro Optical Drive Replacement, Heat Pipe: passo 14, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement, Heat Pipe: passo 14, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two 6 mm silver screws from the metal plate.
    Pergunte ao FixBot
    Comentar
  15. PlayStation 4 Pro Optical Drive Replacement: passo 15, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement: passo 15, imagem 2 %32
    • Lift the metal plate that is connected to the heat pipe straight up to remove it.
    Pergunte ao FixBot
    Comentar
  16. PlayStation 4 Pro Optical Drive Replacement, Optical Drive: passo 16, imagem 1 %32 PlayStation 4 Pro Optical Drive Replacement, Optical Drive: passo 16, imagem 2 %32 PlayStation 4 Pro Optical Drive Replacement, Optical Drive: passo 16, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the four screws.
    • One 30 mm screw.
    • Three 6mm screws.
    • Grab the optical drive and lift up to remove.
    Pergunte ao FixBot
    Comentar
Conclusão
69 outras pessoas executaram este guia.
Thomas
Membro desde: 04/26/17
4.183 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S21-G5, Livingston Spring 2017 Membro de Cal Poly, Team S21-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G5
4 Membros
Autoria de 49 guias
22Comentários do guia
I called an “expert” and they said buying a new drive wont work. I would have to buy a whole new mother board as well…
Vince - Responder Compartilhar
The PS4 Pro does not have a daughter board attached to the optical drive to match up the optical drive model numbers to like the regular PS4. Where do we find what replacement optical drive to buy? Would it be the most recent BDP-025?
David - Responder Compartilhar
I’m currently trying to find a replacement Optical Drive for my Ps4 Pro myself. Apparently, This is really hard to find. Managed to find a used one but the price to me seems a bit high at $123.
Shaquille Moss - Responder Compartilhar
Excellent instructions just saved me a lot of dosh. I would recommend using Phillips #00 where #0 is noted however - worked better for me.
Thanks again though!
Marc Butterworh - Responder Compartilhar
Forgot to say that I my drive was fine once I fished out the two Switch cartridges my 3 year old had posted in there! Obviously wanted to play Zelda on my PS4 pro - if only.
Comentar
Visualizações:
Últimas 24 horas: 31
Últimos 7 dias: 250
Últimos 30 dias: 1,142
Ao todo: 136,807
