Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
PlayStation 2 Slimline SCPH-7500x Motherboard Replacement
O que você precisa
  1. Cuidado: as etapas de 1 a 7 são provenientes de um guia marcado como em andamento.
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  2. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 2, imagem 1 %32
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  3. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 3, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 3, imagem 2 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 3, imagem 3 %32
    • Remove the five visible feet from the bottom of the device using a spudger.
  4. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 4, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the sticker and then remove the 6th foot.
  5. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 5, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 5, imagem 2 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 5, imagem 3 %32
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  6. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 6, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 6, imagem 2 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 6, imagem 3 %32
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
  7. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 7, imagem 1 %32
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  8. Cuidado: a etapa 8 é proveniente de um guia marcado como em andamento.
    PlayStation 2 Slimline SCPH-7500x Motherboard Replacement, IR Sensor: passo 8, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement, IR Sensor: passo 8, imagem 2 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement, IR Sensor: passo 8, imagem 3 %32
    • Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
  9. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement, Clock Battery: passo 9, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement, Clock Battery: passo 9, imagem 2 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement, Clock Battery: passo 9, imagem 3 %32
    • Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
  10. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 10, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 10, imagem 2 %32
    • Gently lift the battery up from the battery compartment using a spudger.
  11. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement, Fan: passo 11, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement, Fan: passo 11, imagem 2 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement, Fan: passo 11, imagem 3 %32
    • Locate the fan component of the motherboard of the PS2.
    • With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
  12. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 12, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 12, imagem 2 %32
    • Detach the terminal (white covering) to the red and yellow cords from the motherboard to the fan with the use of tweezers.
  13. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 13, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 13, imagem 2 %32
    • Locate and unscrew the three 1.6mm screws located next to the base of the fan.
    • They are located off the curved edge of the fan.
    • Once you have removed the three screws, you are able to remove the fan from the PS2.
  14. Cuidado: as etapas de 14 a 18 são provenientes de um guia marcado como em andamento.
    PlayStation 2 Slimline SCPH-7500x Motherboard Replacement, Optical Drive: passo 14, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement, Optical Drive: passo 14, imagem 2 %32
    • Locate the optical drive on the motherboard.
  15. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 15, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 15, imagem 2 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 15, imagem 3 %32
    • Unscrew the four 4.0mm screws that mount the optical drive to the motherboard.
  16. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 16, imagem 1 %32
    • Locate the three ribbons that are attached to the motherboard.
    • Note: These ribbons are different sizes: one large, one medium and one small sized ribbon.
  17. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 17, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 17, imagem 2 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 17, imagem 3 %32
    • Using tweezers, gently detach all three ribbons from the motherboard terminal. Unlock the middle orange ribbon to lift the black tab up on either side.
    • IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it.
  18. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 18, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 18, imagem 2 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 18, imagem 3 %32
    • Gently lift the optical drive away from the motherboard.
  19. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement, Motherboard: passo 19, imagem 1 %32
    • What you see in this picture is the electronic components found in the PS2. We are now going to remove the top metal casing found on top of the motherboard.
  20. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 20, imagem 1 %32
    • Locate the one 2.4mm screw that mounts the metal casing to the top of the motherboard and unscrew the screw with a Philips Screwdriver.
  21. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 21, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 21, imagem 2 %32
    • Gently lift the metal casing from the motherboard and the motherboard from the plastic outer shell. After this step, you should have three separate components: The metal casing, the motherboard and the top half of the outer shell of the PS2.
  22. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 22, imagem 1 %32
    • Take the motherboard and flip it upside down. On the back of the motherboard, you should locate another metal plate that is attached to the back of the motherboard.
  23. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 23, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 23, imagem 2 %32
    • Locate the five 1.6mm screws that mount the metal plate to the motherboard.
    • Note that there are four on one side and one on the other.
  24. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 24, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 24, imagem 2 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 24, imagem 3 %32
    • Unscrew all five screws that mount the metal plate to the motherboard.
  25. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 25, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 25, imagem 2 %32
    • Gently lift the metal plates from the top and the bottom of the motherboard.
  26. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 26, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 26, imagem 2 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 26, imagem 3 %32
    • Remove the plastic film that is sandwiched in between the metal plate and the motherboard.
  27. PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 27, imagem 1 %32 PlayStation 2 Slimline SCPH-7500x Motherboard Replacement: passo 27, imagem 2 %32
    • After you have detached all the other components, it should look like the image shown.
Conclusão
12 outras pessoas executaram este guia.
Jared Hirata
Membro desde: 04/09/13
880 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 17-4, Regan Spring 2013 Membro de Cal Poly, Team 17-4, Regan Spring 2013
CPSU-REGAN-S13S17G4
Membros da 3
Autoria de 28 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 79
Duração total: 7,925
