Introdução
This guide will walk you through step-by-step on how to properly remove and install the IR sensor in the PlayStation 2 Slimline.
Peças
Nenhum componente especificado.
Turn off the PlayStation 2 (or PS2) and carefully unplug from the power source. Check to see there are no discs inside the console before flipping the game system upside-down.
Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
Uma outra pessoa concluiu este guia.
