Ir para o conteúdo principal
Pixel 8 Pro Battery Disconnect
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Pixel 8 Pro Battery Disconnect, Prepare your Pixel for disassembly: passo 1, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Prepare your Pixel for disassembly: passo 1, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Prepare your Pixel for disassembly: passo 1, imagem 3 %32
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Pixel 8 Pro Battery Disconnect, Mark your opening picks: passo 2, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Mark your opening picks: passo 2, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Mark your opening picks: passo 2, imagem 3 %32
    • You'll be using opening picks to separate the screen from the frame. If inserted too far, a pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. Pixel 8 Pro Battery Disconnect, Tape over a cracked screen: passo 3, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Tape over a cracked screen: passo 3, imagem 2 %32
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
    • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  4. Pixel 8 Pro Battery Disconnect, Heat the bottom edge adhesive: passo 4, imagem 1 %32
    • Adhesive and clips secure the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the screen for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as extreme heat can damage the screen and/or battery.
  5. Pixel 8 Pro Battery Disconnect, Secure the Anti-Clamp: passo 5, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Secure the Anti-Clamp: passo 5, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Secure the Anti-Clamp: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
    • Slide the arms over the left edge of your phone, so you have access to the bottom edge.
    • Position the suction cups as close to the center of the bottom edge as possible.
    • Squeeze the cups together to create suction.
  6. Pixel 8 Pro Battery Disconnect, Twist the handle: passo 6, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Twist the handle: passo 6, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Twist the handle: passo 6, imagem 3 %32
    • Pull the handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
  7. Pixel 8 Pro Battery Disconnect, Insert an opening pick: passo 7, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Insert an opening pick: passo 7, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Insert an opening pick: passo 7, imagem 3 %32
    • Wait one minute for a gap to form between the screen and frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat if the screen cools down.
    • Insert an opening pick into the gap.
    • Don't insert your opening pick more than 3 mm to avoid damaging the spring contacts.
    • Pull the blue handle backwards to unlock the arms and remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  8. Pixel 8 Pro Battery Disconnect, Apply a suction cup: passo 8, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Apply a suction cup: passo 8, imagem 2 %32
    • Apply a suction handle to the center of the screen's bottom edge.
  9. Pixel 8 Pro Battery Disconnect, Insert an opening pick: passo 9, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Insert an opening pick: passo 9, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Insert an opening pick: passo 9, imagem 3 %32
    • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
    • If you're having trouble creating a gap, apply more heat and try again.
  10. Pixel 8 Pro Battery Disconnect, Prevent damage to your phone: passo 10, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Prevent damage to your phone: passo 10, imagem 2 %32
    • To avoid damaging your phone, don't insert your pick more than 3 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
  11. Pixel 8 Pro Battery Disconnect, Separate the bottom edge adhesive: passo 11, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Separate the bottom edge adhesive: passo 11, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Separate the bottom edge adhesive: passo 11, imagem 3 %32
    • Slide the opening pick along the bottom edge to separate the adhesive securing it.
    • Leave the pick in the bottom right corner to prevent the adhesive from resealing.
  12. Pixel 8 Pro Battery Disconnect, Heat the right edge adhesive: passo 12, imagem 1 %32
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  13. Pixel 8 Pro Battery Disconnect, Separate the right edge adhesive: passo 13, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Separate the right edge adhesive: passo 13, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Separate the right edge adhesive: passo 13, imagem 3 %32
    • Insert a second opening pick under the bottom right corner of the screen.
    • Slide the new pick to the top right corner to separate the adhesive securing the screen's right edge.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  14. Pixel 8 Pro Battery Disconnect, Leave a pick in the bottom left corner: passo 14, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Leave a pick in the bottom left corner: passo 14, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Leave a pick in the bottom left corner: passo 14, imagem 3 %32
    • Insert a third opening pick under the bottom edge of the screen.
    • Slide the new pick to the bottom left corner.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  15. Pixel 8 Pro Battery Disconnect, Heat the left edge adhesive: passo 15, imagem 1 %32
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  16. Pixel 8 Pro Battery Disconnect, Separate the left edge adhesive: passo 16, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Separate the left edge adhesive: passo 16, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Separate the left edge adhesive: passo 16, imagem 3 %32
    • Insert a fourth opening pick under the bottom left corner of the screen.
    • Slide the new pick to the top left corner to separate the adhesive securing the screen's left edge.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
  17. Pixel 8 Pro Battery Disconnect, Heat the top edge adhesive: passo 17, imagem 1 %32
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  18. Pixel 8 Pro Battery Disconnect, Separate the top edge adhesive: passo 18, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Separate the top edge adhesive: passo 18, imagem 2 %32
    • Insert a fifth opening pick under the top edge of the screen, near the left corner.
    • Slide the opening pick to the top right corner to separate the adhesive securing the screen's top edge.
  19. Pixel 8 Pro Battery Disconnect, Prop up the screen: passo 19, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Prop up the screen: passo 19, imagem 2 %32
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cable.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access the screen cable without straining it.
  20. Pixel 8 Pro Battery Disconnect, Remove the screen cable cover: passo 20, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Remove the screen cable cover: passo 20, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Remove the screen cable cover: passo 20, imagem 3 %32
    • Use an opening tool to pry up the upper edge of the screen cable cover.
    • Remove the cover.
  21. Pixel 8 Pro Battery Disconnect, Disconnect the screen: passo 21, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Disconnect the screen: passo 21, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Disconnect the screen: passo 21, imagem 3 %32
    • Insert the point of a spudger under the top right corner of the screen's press connector.
    • Gently pry up and disconnect the cable.
    • Remove the screen.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  22. Pixel 8 Pro Battery Disconnect, Reassembly information: passo 22, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Reassembly information: passo 22, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Reassembly information: passo 22, imagem 3 %32
    • If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow this guide to apply adhesive to your old screen.
    • Thoroughly check the entire screen for any plastic liners or tape and use the pull tabs to remove all of them. Look carefully for a large piece of plastic covering the back of the screen, a small one near the front camera cutout, and adhesive liners around the perimeter.
    • Reconnect the screen cable and reinstall its cover.
    • This is a good point to test your phone before sealing it up. Temporarily power on your phone and make sure it works as expected. Power it down before continuing.
    • Firmly press the screen into place on the frame—you should feel the clips "pop" into place.
    • Press firmly around the perimeter of the screen to secure it with the new adhesive.
    • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
    • Follow this guide to calibrate the fingerprint sensor.
  23. Pixel 8 Pro Battery Disconnect, Disconnect the 5G mmWave antenna: passo 23, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Disconnect the 5G mmWave antenna: passo 23, imagem 2 %32
    • The next few steps show how to disconnect and detach the 5G mmWave antenna cable. If your phone doesn't have a 5G mmWave antenna, skip the next four steps.
    • Be very careful not to scrape off or damage any surface mounted components during this step.
    • Insert the tip of a spudger under the top edge of the 5G mmWave antenna's press connector.
  24. Pixel 8 Pro Battery Disconnect, Heat the 5G mmWave antenna adhesive: passo 24, imagem 1 %32
  25. Pixel 8 Pro Battery Disconnect, Separate the 5G mmWave antenna adhesive: passo 25, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Separate the 5G mmWave antenna adhesive: passo 25, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Separate the 5G mmWave antenna adhesive: passo 25, imagem 3 %32
    • Insert the flat end of a spudger between the bottom of the 5G mmWave antenna cable and the midframe, just above the press connector.
    • Twist the spudger to separate the bottom of the cable from the midframe.
  26. Pixel 8 Pro Battery Disconnect, Peel up the 5G mmWave antenna: passo 26, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Peel up the 5G mmWave antenna: passo 26, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Peel up the 5G mmWave antenna: passo 26, imagem 3 %32
    Tesa 61395 Tape
    $5.99
    • Grip the bottom of the 5G mmWave antenna cable and gently peel it from the midframe.
    • During reassembly, press the cable back into place on the midframe to secure it with the old adhesive. If it doesn't stick, use thin, double-sided tape to secure it.
  27. Pixel 8 Pro Battery Disconnect, Remove the graphite tape: passo 27, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Remove the graphite tape: passo 27, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Remove the graphite tape: passo 27, imagem 3 %32
    • A large graphite sheet must be removed and replaced to complete this repair. It connects the upper part of the battery, midframe, and the rear cameras.
    • Insert the point of a spudger under different parts of the graphite sheet and lift until you can grip the sheet with your fingers.
    • The sections of graphite sheet between the rear cameras and the battery will most likely tear. If they do, grip the broken part of the sheet and remove that section.
    • Peel up and remove the entire graphite sheet.
    • During reassembly, do not reuse the old graphite sheet. Follow this guide to replace the sheet.
  28. Pixel 8 Pro Battery Disconnect, Move the USB‑C cover tape: passo 28, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Move the USB‑C cover tape: passo 28, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Move the USB‑C cover tape: passo 28, imagem 3 %32
    • Use the tip of a spudger to gently lift the plastic shim that runs along the top of the USB-C port cover.
    • Remove the shim and set it aside or move it out of the way so you can access the USB-C port cover screws.
  29. Pixel 8 Pro Battery Disconnect, Reassembly information: passo 29, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Reassembly information: passo 29, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Reassembly information: passo 29, imagem 3 %32
    • During reassembly, follow this step to replace the plastic shim that runs across the bottom of the midframe and loudspeaker. If you don't have a replacement, press the old one back into place.
    • Remove the larger rectangular liner from the shim.
    • Place the shim so the smaller piece of foam lines up with the bottom of the USB-C port cover.
    • Use the flat end of a spudger to firmly press down along the whole shim to secure it.
    • Remove the remaining liner.
  30. Pixel 8 Pro Battery Disconnect, Remove the USB‑C port cover: passo 30, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Remove the USB‑C port cover: passo 30, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Remove the USB‑C port cover: passo 30, imagem 3 %32
    FixMat
    $36.95
    • While the Pixel 8 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T3 Torx screwdriver to remove the two 5 mm‑long 3IP Torx Plus screws securing the USB‑C port cover.
    • Remove the cover.
  31. Pixel 8 Pro Battery Disconnect, Unfasten the midframe: passo 31, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Unfasten the midframe: passo 31, imagem 2 %32
    • Use a T3 Torx screwdriver to remove the seven 5 mm‑long 3IP Torx Plus screws securing the midframe.
  32. Pixel 8 Pro Battery Disconnect, Remove the midframe: passo 32, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Remove the midframe: passo 32, imagem 2 %32 Pixel 8 Pro Battery Disconnect, Remove the midframe: passo 32, imagem 3 %32
    • Remove the midframe.
    • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
  33. Pixel 8 Pro Battery Disconnect, Disconnect the battery: passo 33, imagem 1 %32 Pixel 8 Pro Battery Disconnect, Disconnect the battery: passo 33, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the battery cable press connector.
Conclusão
Spencer Day
Membro desde: 09/14/22
94.569 Reputação
Autoria de 662 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.418 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 16
