Ir para o conteúdo principal
Photive Rain Battery Replacement
O que você precisa
  1. Photive Rain Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
    Pergunte ao FixBot
    Comentar
  2. Photive Rain Battery Replacement: passo 2, imagem 1 %32
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
    Pergunte ao FixBot
    Comentar
  3. Photive Rain Battery Replacement, Battery: passo 3, imagem 1 %32 Photive Rain Battery Replacement, Battery: passo 3, imagem 2 %32
    • Remove the plastic cover in front of the battery slot.
    • Unscrew all the 8.5mm screws that hold the cover to the slot.
    • Separate the battery from the back panel as shown in photograph 3.
    • Caution: manipulation of the device while the battery is still connected to the motherboard may result in electric shock.
    Pergunte ao FixBot
    Comentar
  4. Photive Rain Battery Replacement: passo 4, imagem 1 %32
    • Remove the battery from the motherboard.
    • Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
    • Click here to access the iFixit Soldering Guide. This will provide a safe and instructive manual on the usage of soldering pens.
    Pergunte ao FixBot
    Comentar
Conclusão
abcdef ghijk
Membro desde: 02/15/16
723 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team 1-4, Harley Spring 2016 Membro de IUPUI, Team 1-4, Harley Spring 2016
IUPUI-HARLEY-S16S1G4
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 24
Ao todo: 803
