Ir para o conteúdo principal
Pentax Optio WG-2 LCD Screen Replacement
O que você precisa
  1. Cuidado: os passos de 1 a 6 são provenientes de um guia marcado como em andamento.
    Pentax Optio WG-2 LCD Screen Replacement, Back Case: passo 1, imagem 1 %32 Pentax Optio WG-2 LCD Screen Replacement, Back Case: passo 1, imagem 2 %32
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Pentax Optio WG-2 LCD Screen Replacement: passo 2, imagem 1 %32
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Pentax Optio WG-2 LCD Screen Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Pentax Optio WG-2 LCD Screen Replacement: passo 4, imagem 1 %32 Pentax Optio WG-2 LCD Screen Replacement: passo 4, imagem 2 %32 Pentax Optio WG-2 LCD Screen Replacement: passo 4, imagem 3 %32
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  5. Pentax Optio WG-2 LCD Screen Replacement: passo 5, imagem 1 %32
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  6. Pentax Optio WG-2 LCD Screen Replacement: passo 6, imagem 1 %32
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  7. Pentax Optio WG-2 LCD Screen Replacement, LCD Screen: passo 7, imagem 1 %32 Pentax Optio WG-2 LCD Screen Replacement, LCD Screen: passo 7, imagem 2 %32
    • Carefully remove the clear tape covering the screws and the ribbon cable.
    • Be careful not to tear the ribbon cable when removing the tape.
    • We want to remove the larger silver panel (right). The best way to do this is to slightly bend the cover backwards and use the tweezers to grab a corner and slowly lift the screen up and out.
  8. Pentax Optio WG-2 LCD Screen Replacement: passo 8, imagem 1 %32 Pentax Optio WG-2 LCD Screen Replacement: passo 8, imagem 2 %32
    • Once the screen is removed you should have two pieces as seen in the picture.
    • The screen is the silver rectangle in the top of the picture or the component seen in picture two.
Conclusão
Matthew Bessette
Membro desde: 03/04/16
658 Reputação
Autoria de 6 guias
Equipe
2 comentários
Dónde puedo comprar el Display?
Where I can buy the dispaly?
Sebastian Mesa - Responder
opération réussie ça marche nickel la plus grosse difficultée est de remettre correctement les 3 connecteurs
impératif: utiliser les bons outils comme indiqué attention aux vis il y a un petit joint et les longueurs différentes ne pas mélanger !!!
merci pour ce super tuto ….
walchkorn - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 889
