Ir para o conteúdo principal
Pebble Time Battery Replacement
O que você precisa
    1. Pebble Time Battery Replacement, Screen Cover: passo 1, imagem 1 %32
      • Lay the watch flat on your workstation.
      Pergunte ao FixBot
      Comentar
    2. Pebble Time Battery Replacement: passo 2, imagem 1 %32 Pebble Time Battery Replacement: passo 2, imagem 2 %32
      • Use the metal spudger to carefully pull apart the screen cover from the case.
      • Replace the metal spudger with a plastic opening tool to hold the cover open.
      Pergunte ao FixBot
      Comentar
    3. Pebble Time Battery Replacement: passo 3, imagem 1 %32
      • Use the metal spudger tool to carefully loosen the rest of the cover.
      Pergunte ao FixBot
      Comentar
    4. Pebble Time Battery Replacement: passo 4, imagem 1 %32
      • Carefully, pull apart the cover with the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    1. Pebble Time Battery Replacement, Screen: passo 5, imagem 1 %32
      • Insert metal spudger into the side of the screen shown in the picture.
      Pergunte ao FixBot
      Comentar
    2. Pebble Time Battery Replacement: passo 6, imagem 1 %32
      • Use the metal spudger to pry the screen up.
      Pergunte ao FixBot
      Comentar
    3. Pebble Time Battery Replacement: passo 7, imagem 1 %32 Pebble Time Battery Replacement: passo 7, imagem 2 %32 Pebble Time Battery Replacement: passo 7, imagem 3 %32
      • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
      • Disconnect the screen from the circuit board.
      Pergunte ao FixBot
      Comentar
    1. Pebble Time Battery Replacement, Circuit Board: passo 8, imagem 1 %32
      • Keep the watch flat on your workstation.
      Pergunte ao FixBot
      Comentar
    2. Pebble Time Battery Replacement: passo 9, imagem 1 %32
      • Locate the three screws on the circuit board.
      • Remove using the J000 Philips head screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Pebble Time Battery Replacement: passo 10, imagem 1 %32 Pebble Time Battery Replacement: passo 10, imagem 2 %32 Pebble Time Battery Replacement: passo 10, imagem 3 %32
      • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
      • Move apart the connector to expose the fourth screw.
      Pergunte ao FixBot
      Comentar
    4. Pebble Time Battery Replacement: passo 11, imagem 1 %32
      • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Pebble Time Battery Replacement: passo 12, imagem 1 %32 Pebble Time Battery Replacement: passo 12, imagem 2 %32
      • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
      • Remove the circuit board from the case.
      Pergunte ao FixBot
      Comentar
    1. Pebble Time Battery Replacement, Battery: passo 13, imagem 1 %32
      • After removing the circuit board, the battery is located in the middle of the case.
      Pergunte ao FixBot
      Comentar
    2. Pebble Time Battery Replacement: passo 14, imagem 1 %32 Pebble Time Battery Replacement: passo 14, imagem 2 %32
      • Locate the battery connector on the left side of the case.
      • Carefully disconnect the wire using a metal spudger.
      Pergunte ao FixBot
      Comentar
    3. Pebble Time Battery Replacement: passo 15, imagem 1 %32 Pebble Time Battery Replacement: passo 15, imagem 2 %32
      • After disconnecting the battery use the plastic opening tool to lift the battery off of the case.
      • The battery might be glued to the case.
      Pergunte ao FixBot
      Comentar
Conclusão
35 outras pessoas executaram este guia.
Nicolas Hempe
Membro desde: 02/15/17
1.516 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-3, Sullivan Spring 2017 Membro de USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Membros
Autoria de 10 guias
12Comentários do guia
Where did you purchase the replacement battery?
Dimas Caparros - Responder Compartilhar
Got mine on Amazon
kwojdak - Responder Compartilhar
What is everyone using for sticky tape to hold the bezel/crystal on that will ensure the pebble is still waterproof?
Shannon Oswald - Responder Compartilhar
Attempted this using RTV Silicon, and it is %#*@ difficult to not get it EVERYWHERE! I got some on my LCD, now I’m looking for another Pebble. Just use a little superglue on the outside and don’t figure on it being waterproof anymore - I guess.
There’s a lot of replacement battery on internet. Just search “150mAh P11G7T-01-S01”.
Xie Yanbo - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 41
Últimos 30 dias: 181
Ao todo: 27,749
