Ir para o conteúdo principal
Parrot Skycontroller 2 USB Port Replacement
O que você precisa
  1. Parrot Skycontroller 2 USB Port Replacement, Battery: passo 1, imagem 1 %32 Parrot Skycontroller 2 USB Port Replacement, Battery: passo 1, imagem 2 %32 Parrot Skycontroller 2 USB Port Replacement, Battery: passo 1, imagem 3 %32
    • Flip your controller face down.
  2. Parrot Skycontroller 2 USB Port Replacement: passo 2, imagem 1 %32
    • Remove one 9mm screw using a #4 flathead screwdriver.
  3. Parrot Skycontroller 2 USB Port Replacement: passo 3, imagem 1 %32 Parrot Skycontroller 2 USB Port Replacement: passo 3, imagem 2 %32 Parrot Skycontroller 2 USB Port Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
  4. Parrot Skycontroller 2 USB Port Replacement: passo 4, imagem 1 %32 Parrot Skycontroller 2 USB Port Replacement: passo 4, imagem 2 %32 Parrot Skycontroller 2 USB Port Replacement: passo 4, imagem 3 %32
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
  5. Parrot Skycontroller 2 USB Port Replacement: passo 5, imagem 1 %32 Parrot Skycontroller 2 USB Port Replacement: passo 5, imagem 2 %32
    • Remove the battery from its brackets by pulling up on the ends of the battery.
  6. Parrot Skycontroller 2 USB Port Replacement, USB Port: passo 6, imagem 1 %32
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
    • Pull back the sticker with your finger nail and remove one 11mm screws using the Torx TR6 screwdriver.
    • There is a hidden screw located behind the sticker in the battery compartment.
  7. Parrot Skycontroller 2 USB Port Replacement: passo 7, imagem 1 %32 Parrot Skycontroller 2 USB Port Replacement: passo 7, imagem 2 %32 Parrot Skycontroller 2 USB Port Replacement: passo 7, imagem 3 %32
    • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
  8. Parrot Skycontroller 2 USB Port Replacement: passo 8, imagem 1 %32
    • Remove the battery compartment plate by pulling up and out.
  9. Parrot Skycontroller 2 USB Port Replacement: passo 9, imagem 1 %32 Parrot Skycontroller 2 USB Port Replacement: passo 9, imagem 2 %32
    • Remove the top plate by pushing on the corners with your hand.
    • Be careful to not pull too hard on the cable.
  10. Parrot Skycontroller 2 USB Port Replacement: passo 10, imagem 1 %32 Parrot Skycontroller 2 USB Port Replacement: passo 10, imagem 2 %32
    • Remove the face plate by pulling up and out.
  11. Parrot Skycontroller 2 USB Port Replacement: passo 11, imagem 1 %32 Parrot Skycontroller 2 USB Port Replacement: passo 11, imagem 2 %32 Parrot Skycontroller 2 USB Port Replacement: passo 11, imagem 3 %32
    • Position the device so that the top panel is flat down on the table. You should have access to the USB Port.
    • Desolder the two connection points in the back of the USB port.
    • Desolder the four wires in the back of the USB port.
    • Remove the the component from the board.
    • Excessive heat can damage the port, so do not apply the soldering iron to the component for too long.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 17
Ao todo: 930
