Ir para o conteúdo principal
Orbo Jr. Speaker Replacement
O que você precisa
  1. Orbo Jr. Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Use your thumbs to gently pry the silicon case away from the tablet starting at one of the corners. Once the first corner is separated the other three corners should slip off easily.
    Pergunte ao FixBot
    Comentar
  2. Orbo Jr. Speaker Replacement: passo 2, imagem 1 %32 Orbo Jr. Speaker Replacement: passo 2, imagem 2 %32 Orbo Jr. Speaker Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the back off the tablet. Work your way around the edges. Once you have one side open you can slowly unsnap the rest of the case and use the tool as needed.
    • Go slowly when you pry the back off to ensure you do not crack the case or damage the screen.
    Pergunte ao FixBot
    Comentar
  3. Orbo Jr. Speaker Replacement: passo 3, imagem 1 %32
    • Gently pull the cables attached to the speaker to remove it from the back cover.
    • The speaker is taped in the back cover and caution should be used when pulling on the wires.
    Pergunte ao FixBot
    Comentar
  4. Orbo Jr. Speaker Replacement: passo 4, imagem 1 %32
    • Pull back the tape to expose the wires that are attached to the battery.
    Pergunte ao FixBot
    Comentar
  5. Orbo Jr. Speaker Replacement: passo 5, imagem 1 %32 Orbo Jr. Speaker Replacement: passo 5, imagem 2 %32
    • Do not attempt to fully remove the battery. It is still connected to the motherboard by two wires.
    • Use a nylon spudger to lift the battery from the right side of the device. Slowly remove the adhesive below the battery.
    • To avoid damage to device and battery, do not attempt to remove the battery until adhesive is completely detached.
    Pergunte ao FixBot
    Comentar
  6. Orbo Jr. Speaker Replacement: passo 6, imagem 1 %32 Orbo Jr. Speaker Replacement: passo 6, imagem 2 %32 Orbo Jr. Speaker Replacement: passo 6, imagem 3 %32
    • Desolder the battery wires from the positive and negative connection to the motherboard. Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
    • Positive and Negative battery terminals.
    • Be careful to not make contact to other components on the motherboard while using the soldering iron.
    Pergunte ao FixBot
    Comentar
  7. Orbo Jr. Speaker Replacement, Speaker: passo 7, imagem 1 %32 Orbo Jr. Speaker Replacement, Speaker: passo 7, imagem 2 %32 Orbo Jr. Speaker Replacement, Speaker: passo 7, imagem 3 %32
    • Unsolder the positive and negative speaker wires from the connection on the motherboard.
    • Be careful to not make contact to other components on the motherboard while using the solder iron.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Christman
Membro desde: 02/10/16
684 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-1, Sullivan Spring 2016 Membro de USF Tampa, Team 3-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G1
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 39
Ao todo: 491
