Ir para o conteúdo principal
Oral-B White Pro 1000 Motherboard Replacement
O que você precisa
  1. Oral-B White Pro 1000 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the brush head by pulling the top away from the base.
  2. Oral-B White Pro 1000 Motherboard Replacement: passo 2, imagem 1 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 2, imagem 2 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 2, imagem 3 %32
    • Pry open the end cap from the toothbrush body.
    • Remove the spring.
  3. Oral-B White Pro 1000 Motherboard Replacement: passo 3, imagem 1 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 3, imagem 2 %32
    • Apply pressure on the brush shaft to release the toothbrush internals.
    • Remove the internals through the bottom of the toothbrush body.
  4. Oral-B White Pro 1000 Motherboard Replacement: passo 4, imagem 1 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 4, imagem 2 %32
    • Use flat head screwdriver to remove power button pressure plate.
  5. Oral-B White Pro 1000 Motherboard Replacement: passo 5, imagem 1 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 5, imagem 2 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 5, imagem 3 %32
    • Desolder the coil wire from the motherboard.
    • Check out this helpful guide for some soldering and desoldering tips.
    • Squeeze and remove coil from motherboard.
  6. Oral-B White Pro 1000 Motherboard Replacement: passo 6, imagem 1 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 6, imagem 2 %32
    • Desolder the motor from motherboard.
    • Remove motherboard and battery from body of toothbrush internals.
  7. Oral-B White Pro 1000 Motherboard Replacement: passo 7, imagem 1 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 7, imagem 2 %32
    • Desolder the battery connections from the motherboard.
    • Remove motherboard from battery holder.
Conclusão
Reattach new motherboard and reassemble your device following instructions in reverse order. Solder appropriate connections during reassembly.
3 outras pessoas executaram este guia.
Hannah Parker
Membro desde: 11/08/17
221 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S5-G4, Baechle Fall 2017 Membro de IUPUI, Team S5-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G4
3 Membros
Autoria de 8 guias
1Comentário do guia
Motor are brushless?
joseferreira_ms - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 12
Últimos 30 dias: 69
Ao todo: 3,264
