Ir para o conteúdo principal
OnePlus 7T Rear Glass Replacement
O que você precisa
  1. OnePlus 7T Rear Glass Replacement, Heat the rear glass: passo 1, imagem 1 %32
    • Be sure to power off your phone before you begin.
    • Apply a heated iOpener to the rear glass for two minutes to loosen the adhesive beneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. OnePlus 7T Rear Glass Replacement, Insert an opening pick: passo 2, imagem 1 %32 OnePlus 7T Rear Glass Replacement, Insert an opening pick: passo 2, imagem 2 %32 OnePlus 7T Rear Glass Replacement, Insert an opening pick: passo 2, imagem 3 %32
    • Apply a suction handle to the right edge of the rear glass.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull on the suction handle to create a gap between the rear glass and the frame.
    • Insert an opening pick into the gap.
  3. OnePlus 7T Rear Glass Replacement, Slice the adhesive: passo 3, imagem 1 %32 OnePlus 7T Rear Glass Replacement, Slice the adhesive: passo 3, imagem 2 %32 OnePlus 7T Rear Glass Replacement, Slice the adhesive: passo 3, imagem 3 %32
    • Slide the opening pick along the edge to the bottom right corner.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
    • Once you have inserted an opening pick, feel free to remove the suction handle or continue to use it for a better grip during this process.
  4. OnePlus 7T Rear Glass Replacement: passo 4, imagem 1 %32 OnePlus 7T Rear Glass Replacement: passo 4, imagem 2 %32 OnePlus 7T Rear Glass Replacement: passo 4, imagem 3 %32
    • Insert a second opening pick in the gap you just created.
    • Slide the opening pick along the edge to the top right corner.
    • If you have trouble with slicing, you can use the iOpener again to soften the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  5. OnePlus 7T Rear Glass Replacement: passo 5, imagem 1 %32 OnePlus 7T Rear Glass Replacement: passo 5, imagem 2 %32 OnePlus 7T Rear Glass Replacement: passo 5, imagem 3 %32
    • When you slice near the camera assembly, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
    • Insert a third opening pick under the top right corner of the rear glass.
    • Slide the opening pick along the edge of the phone to the top left corner to cut the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. OnePlus 7T Rear Glass Replacement: passo 6, imagem 1 %32 OnePlus 7T Rear Glass Replacement: passo 6, imagem 2 %32 OnePlus 7T Rear Glass Replacement: passo 6, imagem 3 %32
    • Insert a fourth opening pick under the top left corner.
    • Slide the opening pick along the edge to the bottom left corner to cut the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  7. OnePlus 7T Rear Glass Replacement: passo 7, imagem 1 %32 OnePlus 7T Rear Glass Replacement: passo 7, imagem 2 %32
    • Insert a fifth opening pick under the bottom left corner.
    • Slide it along the the edge to the bottom right corner to cut the remaining adhesive.
  8. OnePlus 7T Rear Glass Replacement, Remove the rear glass: passo 8, imagem 1 %32
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
5 outras pessoas executaram este guia.
Manuel Haeussermann
Membro desde: 07/13/22
22.747 Reputação
Autoria de 71 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 57
Ao todo: 5,064
