Ir para o conteúdo principal
OnePlus 6T Front Camera Replacement
O que você precisa
  1. OnePlus 6T Front Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
    Pergunte ao FixBot
    Comentar
  2. OnePlus 6T Front Camera Replacement: passo 2, imagem 1 %32
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    Pergunte ao FixBot
    Comentar
  3. OnePlus 6T Front Camera Replacement: passo 3, imagem 1 %32
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
    Pergunte ao FixBot
    Comentar
  4. OnePlus 6T Front Camera Replacement: passo 4, imagem 1 %32 OnePlus 6T Front Camera Replacement: passo 4, imagem 2 %32 OnePlus 6T Front Camera Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    Pergunte ao FixBot
    Comentar
  5. OnePlus 6T Front Camera Replacement, Front Camera: passo 5, imagem 1 %32 OnePlus 6T Front Camera Replacement, Front Camera: passo 5, imagem 2 %32
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
    Pergunte ao FixBot
    Comentar
  6. OnePlus 6T Front Camera Replacement: passo 6, imagem 1 %32
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
    Pergunte ao FixBot
    Comentar
  7. OnePlus 6T Front Camera Replacement: passo 7, imagem 1 %32
    • Using a spudger, gently remove the midframe and place it to the side.
    Pergunte ao FixBot
    Comentar
  8. OnePlus 6T Front Camera Replacement: passo 8, imagem 1 %32
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Kristen Gismondi
Membro desde: 11/12/14
107.622 Reputação
Autoria de 270 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.617 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 60
Ao todo: 1,769
