Ir para o conteúdo principal
OnePlus 6T Back Cover Replacement
O que você precisa
  1. OnePlus 6T Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
    Pergunte ao FixBot
    Comentar
  2. OnePlus 6T Back Cover Replacement: passo 2, imagem 1 %32
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    Pergunte ao FixBot
    Comentar
  3. OnePlus 6T Back Cover Replacement: passo 3, imagem 1 %32
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
    Pergunte ao FixBot
    Comentar
  4. OnePlus 6T Back Cover Replacement: passo 4, imagem 1 %32 OnePlus 6T Back Cover Replacement: passo 4, imagem 2 %32 OnePlus 6T Back Cover Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    Pergunte ao FixBot
    Comentar
Conclusão
19 outras pessoas executaram este guia.
6Comentários do guia
I wonder if this is the same for OnePlus 6 (6000/6003)?
karlkristians - Responder Compartilhar
another greath guide, repaird check.
In same time rplacd the battery so phone is ready for another few years
yoeri - Responder Compartilhar
Thanks for this guide. But is there something particular after removing the old piece to install the new one ? How the new one will be glued ?
Alexandre Herbreteau - Responder Compartilhar
Preciso de uma tela para o one plus 6t
Fred Silva - Responder Compartilhar
Tela one plus 6t quem sabe onde ou se alguém vende
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 32
Últimos 30 dias: 112
Ao todo: 21,112
