Ir para o conteúdo principal
OnePlus 5 Battery Replacement
O que você precisa
  1. OnePlus 5 Battery Replacement, SIM Card Tray: passo 1, imagem 1 %32 OnePlus 5 Battery Replacement, SIM Card Tray: passo 1, imagem 2 %32 OnePlus 5 Battery Replacement, SIM Card Tray: passo 1, imagem 3 %32
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
    • Press firmly to eject the tray.
    • During reassembly, be sure to properly orient the SIM tray you you insert it.
    Pergunte ao FixBot
    Comentar
  2. OnePlus 5 Battery Replacement, Back Cover: passo 2, imagem 1 %32
    • Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
    Pergunte ao FixBot
    Comentar
  3. OnePlus 5 Battery Replacement: passo 3, imagem 1 %32 OnePlus 5 Battery Replacement: passo 3, imagem 2 %32 OnePlus 5 Battery Replacement: passo 3, imagem 3 %32
    • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
    • The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
    • There are two different seams between the body and the screen of the phone:
    • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
    • Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
    • There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
    Pergunte ao FixBot
    Comentar
  4. OnePlus 5 Battery Replacement: passo 4, imagem 1 %32 OnePlus 5 Battery Replacement: passo 4, imagem 2 %32
    • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
    • Place a suction cup near the bottom edge of the display.
    • Pull on the suction cup with strong steady force.
    • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
    • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
    Pergunte ao FixBot
    Comentar
  5. OnePlus 5 Battery Replacement: passo 5, imagem 1 %32 OnePlus 5 Battery Replacement: passo 5, imagem 2 %32 OnePlus 5 Battery Replacement: passo 5, imagem 3 %32
    • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
    • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
    Pergunte ao FixBot
    Comentar
  6. OnePlus 5 Battery Replacement: passo 6, imagem 1 %32 OnePlus 5 Battery Replacement: passo 6, imagem 2 %32
    • Lever the opening tool to release the first clip from the frame.
    Pergunte ao FixBot
    Comentar
  7. OnePlus 5 Battery Replacement: passo 7, imagem 1 %32 OnePlus 5 Battery Replacement: passo 7, imagem 2 %32 OnePlus 5 Battery Replacement: passo 7, imagem 3 %32
    • Continue sliding the opening tool along the long edge, releasing the clips along the way.
    • The last clip in the top-left corner near the front-facing camera is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
    Pergunte ao FixBot
    Comentar
  8. OnePlus 5 Battery Replacement: passo 8, imagem 1 %32
    • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
    • The frame is still connected to the back cover by a long flex cable. Do not remove the back cover.
    • During reassembly, pause here to test your phone's functionality before securing the back cover.
    • To reinstall the back cover:
    • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
    • Squeeze along the long edges of the phone to snap the remaining clips into place.
    Pergunte ao FixBot
    Comentar
  9. OnePlus 5 Battery Replacement: passo 9, imagem 1 %32 OnePlus 5 Battery Replacement: passo 9, imagem 2 %32 OnePlus 5 Battery Replacement: passo 9, imagem 3 %32
    • With all the clips released, flip the phone over so that the display is face-down.
    • Swing the back cover around and rest it on top of the exposed frame.
    • Be careful not to stress the flex cable connecting the back cover and the frame.
    Pergunte ao FixBot
    Comentar
  10. OnePlus 5 Battery Replacement: passo 10, imagem 1 %32 OnePlus 5 Battery Replacement: passo 10, imagem 2 %32
    • Remove the 2.6 mm Phillips screw holding the cable bracket above the battery in place.
    • Lift up and remove the cable bracket.
    • To reinstall the bracket, position one end into place, and bend the bracket slightly to spring the other end into place.
    Pergunte ao FixBot
    Comentar
  11. OnePlus 5 Battery Replacement: passo 11, imagem 1 %32 OnePlus 5 Battery Replacement: passo 11, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Pergunte ao FixBot
    Comentar
  12. OnePlus 5 Battery Replacement: passo 12, imagem 1 %32
    • Remove the back cover.
    Pergunte ao FixBot
    Comentar
  13. OnePlus 5 Battery Replacement, OnePlus 5 Battery Disconnect: passo 13, imagem 1 %32 OnePlus 5 Battery Replacement, OnePlus 5 Battery Disconnect: passo 13, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket.
    Pergunte ao FixBot
    Comentar
  14. OnePlus 5 Battery Replacement, Loudspeaker: passo 14, imagem 1 %32
    • Remove the six 2.6 mm Phillips screws securing the loudspeaker to the frame.
    Pergunte ao FixBot
    Comentar
  15. OnePlus 5 Battery Replacement: passo 15, imagem 1 %32 OnePlus 5 Battery Replacement: passo 15, imagem 2 %32
    • Insert the flat end of a spudger into the corner of the loudspeaker assembly and pry slightly, loosening the loudspeaker from its recess.
    Pergunte ao FixBot
    Comentar
  16. OnePlus 5 Battery Replacement: passo 16, imagem 1 %32
    • Remove the loudspeaker.
    • To reinstall the loudspeaker, align the loudspeaker's bottom edge to the frame, then press the assembly into place.
    • During reinstallation, make sure that the display cable connector under the loudspeaker assembly is still securely fastened.
    Pergunte ao FixBot
    Comentar
  17. OnePlus 5 Battery Replacement, OnePlus 5 Interconnect Cable Disconnect: passo 17, imagem 1 %32 OnePlus 5 Battery Replacement, OnePlus 5 Interconnect Cable Disconnect: passo 17, imagem 2 %32 OnePlus 5 Battery Replacement, OnePlus 5 Interconnect Cable Disconnect: passo 17, imagem 3 %32
    • Use the point of a spudger to pry up and disconnect the interconnect flex cable from the socket.
    • If you are replacing the battery, bend the interconnect flex cable away from the phone and secure it out of the way with a rubber band or tape.
    Pergunte ao FixBot
    Comentar
  18. OnePlus 5 Battery Replacement, Battery: passo 18, imagem 1 %32
    • Peel the green pull tab up from the battery.
    Pergunte ao FixBot
    Comentar
  19. OnePlus 5 Battery Replacement: passo 19, imagem 1 %32 OnePlus 5 Battery Replacement: passo 19, imagem 2 %32 OnePlus 5 Battery Replacement: passo 19, imagem 3 %32
    • Brace the phone frame against the table.
    • Using a strong, steady force, pull the green pull tab upwards until the battery loosens from its recess.
    • If you are having a hard time, apply some high concentration (over 90%) isopropyl alcohol along the battery seam to help weaken the adhesive.
    • Swing the battery completely out of its recess and pull it off of the plastic liner.
    Pergunte ao FixBot
    Comentar
  20. OnePlus 5 Battery Replacement: passo 20, imagem 1 %32
    • Remove the battery.
    • Do not reuse the battery after it has been removed. Reusing a battery that is bent or otherwise stressed is a potential safety hazard.
    • If your replacement battery did not come with a green pull tab, you can transfer the old tab to the new battery to help with subsequent replacements.
    • While installing a new battery, temporarily connect the battery to the phone to ensure proper battery alignment.
    • If you are installing a battery onto a new screen and digitizer assembly, be sure to peel off the dark blue adhesive liners to expose the battery adhesive for the new battery.
    Pergunte ao FixBot
    Comentar
Conclusão
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our OnePlus 5 Answers community for troubleshooting help.
98 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
338.119 Reputação
Autoria de 851 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.593 guias
29Comentários do guia
Thanks a lot for your contribution! It worked perfectly.
Kyuhwa Lee - Responder Compartilhar
I follow the instructions but it said the battery is too slow
Jhonny Cheong - Responder Compartilhar
Charge the battery for at least a few hours. If the battery does not charge, double-check all connectors, especially the interconnect cable. Does the phone react to a charging cable? If not, something may be broken between the USB port and the motherboard.
Arthur Shi - Responder Compartilhar
It honestly took an hour to get the back cover off, and then another hour to take the rest apart and put it back together. But this guide was useful.
Matthew MacDonald - Responder Compartilhar
Thanks so much for this guide. Worked out great!
johndbattles - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 71
Últimos 30 dias: 282
Ao todo: 59,432
