Ir para o conteúdo principal
OnePlus 3 Front-Facing Camera Replacement
O que você precisa
  1. OnePlus 3 Front-Facing Camera Replacement, SIM Card Tray: passo 1, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement, SIM Card Tray: passo 1, imagem 2 %32 OnePlus 3 Front-Facing Camera Replacement, SIM Card Tray: passo 1, imagem 3 %32
    • Insert a SIM eject tool, bit, or straightened paperclip into the hole located between the SIM card slot and the power button.
    • Press firmly to eject the SIM card tray.
    • During reinstallation, make sure that the SIM card tray is properly oriented. It fits in only one direction.
    Pergunte ao FixBot
    Comentar
  2. OnePlus 3 Front-Facing Camera Replacement, Back Cover: passo 2, imagem 1 %32
    • Remove the two 2.6 mm T2 screws from the bottom edge of the phone.
    Pergunte ao FixBot
    Comentar
  3. OnePlus 3 Front-Facing Camera Replacement: passo 3, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement: passo 3, imagem 2 %32 OnePlus 3 Front-Facing Camera Replacement: passo 3, imagem 3 %32
    • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
    • The following three steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
    • There are two different seams between the screen and the body of the phone:
    • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
    • Frame seam: This is where the plastic frame meets the back cover. It is recessed into the back cover. Only pry at this seam.
    • There are fourteen clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
    Pergunte ao FixBot
    Comentar
  4. OnePlus 3 Front-Facing Camera Replacement: passo 4, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement: passo 4, imagem 2 %32 OnePlus 3 Front-Facing Camera Replacement: passo 4, imagem 3 %32
    • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
    • Place a suction cup near the bottom edge of the display.
    • Pull on the suction cup with strong steady force.
    • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
    • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
    • Do not use metal tools, as they will most likely crack the screen.
    Pergunte ao FixBot
    Comentar
  5. OnePlus 3 Front-Facing Camera Replacement: passo 5, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement: passo 5, imagem 2 %32 OnePlus 3 Front-Facing Camera Replacement: passo 5, imagem 3 %32
    • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
    • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
    Pergunte ao FixBot
    Comentar
  6. OnePlus 3 Front-Facing Camera Replacement: passo 6, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement: passo 6, imagem 2 %32
    • Continue sliding the opening tool along the long edge, releasing the clips along the way.
    • The last clip in the top-left corner near the alert switch is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
    Pergunte ao FixBot
    Comentar
  7. OnePlus 3 Front-Facing Camera Replacement: passo 7, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement: passo 7, imagem 2 %32 OnePlus 3 Front-Facing Camera Replacement: passo 7, imagem 3 %32
    • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
    • Lift the screen up and remove it.
    • During reassembly, pause here to test your phone's functionality before securing the back cover.
    • To reinstall the back cover:
    • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
    • Squeeze along the long edges of the phone to snap the remaining clips into place.
    Pergunte ao FixBot
    Comentar
  8. OnePlus 3 Front-Facing Camera Replacement, OnePlus 3 Battery Disconnect: passo 8, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement, OnePlus 3 Battery Disconnect: passo 8, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket, located above the top right corner of the battery pack.
    • Bend the connector away from the socket to prevent accidental contact.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Pergunte ao FixBot
    Comentar
  9. OnePlus 3 Front-Facing Camera Replacement, OnePlus 3 Interconnect Cable Disconnect: passo 9, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement, OnePlus 3 Interconnect Cable Disconnect: passo 9, imagem 2 %32
    • Remove the 3 mm Phillips screw securing the cable bracket.
    • Remove the cable bracket.
    Pergunte ao FixBot
    Comentar
  10. OnePlus 3 Front-Facing Camera Replacement: passo 10, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement: passo 10, imagem 2 %32 OnePlus 3 Front-Facing Camera Replacement: passo 10, imagem 3 %32
    • Use the point of a spudger to pry up and disconnect the interconnect flex cable from the motherboard, which is located above the battery.
    • Repeat the process to disconnect the daughterboard flex cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  11. OnePlus 3 Front-Facing Camera Replacement, Motherboard: passo 11, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement, Motherboard: passo 11, imagem 2 %32
    • Slide the point of a spudger underneath the antenna interconnect cable located at the bottom left corner of the motherboard.
    • Pry up and disconnect the antenna interconnect cable.
    Pergunte ao FixBot
    Comentar
  12. OnePlus 3 Front-Facing Camera Replacement: passo 12, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement: passo 12, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the display connector from its socket on the motherboard.
    Pergunte ao FixBot
    Comentar
  13. OnePlus 3 Front-Facing Camera Replacement: passo 13, imagem 1 %32
    • Remove the seven Phillips screws securing the motherboard to the frame:
    • Four 3 mm black screws
    • Three 2.9 mm silver screws
    • Some of these screws may be covered by stickers. Remove the stickers to access the screws.
    Pergunte ao FixBot
    Comentar
  14. OnePlus 3 Front-Facing Camera Replacement: passo 14, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement: passo 14, imagem 2 %32 OnePlus 3 Front-Facing Camera Replacement: passo 14, imagem 3 %32
    • Make sure you have ejected the SIM tray before performing this step.
    • The motherboard is still held in place near the top by clips.
    • Slide the flat end of a spudger underneath the top left corner of the motherboard.
    • Twist the spudger and pry up to release the motherboard from its recess.
    Pergunte ao FixBot
    Comentar
  15. OnePlus 3 Front-Facing Camera Replacement: passo 15, imagem 1 %32
    • Remove the motherboard.
    • During reinstallation, be careful not to trap any flex cables or antenna cables underneath the motherboard.
    Pergunte ao FixBot
    Comentar
  16. OnePlus 3 Front-Facing Camera Replacement, Front-Facing Camera: passo 16, imagem 1 %32 OnePlus 3 Front-Facing Camera Replacement, Front-Facing Camera: passo 16, imagem 2 %32
    • Flip the motherboard over so that the front-facing camera is facing up.
    • Use the point of a spudger to pry up and disconnect the front-facing camera connector from its motherboard socket.
    Pergunte ao FixBot
    Comentar
  17. OnePlus 3 Front-Facing Camera Replacement: passo 17, imagem 1 %32
    • Flip the motherboard over again.
    • Peel the front-facing camera away from the motherboard with its tape.
    • Remove the front-facing camera.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Check out our OnePlus 3 Answers community for troubleshooting help.
3 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
338.301 Reputação
Autoria de 851 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 41
Ao todo: 4,988
