Ir para o conteúdo principal
OnHub Speaker Replacement
O que você precisa
  1. OnHub Speaker Replacement, Speaker Grille: passo 1, imagem 1 %32 OnHub Speaker Replacement, Speaker Grille: passo 1, imagem 2 %32
    • Make sure the device is unplugged before proceeding with the disassembly.
    • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
    Pergunte ao FixBot
    Comentar
  2. OnHub Speaker Replacement: passo 2, imagem 1 %32
    • Place the plastic opening tool under the speaker grille, and just above the light ring.
    • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
    Pergunte ao FixBot
    Comentar
  3. OnHub Speaker Replacement: passo 3, imagem 1 %32 OnHub Speaker Replacement: passo 3, imagem 2 %32
    • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
    • There is a delicate wire connection to the antenna that is easily broken if not careful.
    Pergunte ao FixBot
    Comentar
  4. OnHub Speaker Replacement, Congestion-sensing Antenna: passo 4, imagem 1 %32 OnHub Speaker Replacement, Congestion-sensing Antenna: passo 4, imagem 2 %32
    • Remove the wire connection to the antenna by soldering it off.
    • For help with soldering and de-soldering check out the iFixit Soldering Guide
    Pergunte ao FixBot
    Comentar
  5. OnHub Speaker Replacement, Outer Casing: passo 5, imagem 1 %32 OnHub Speaker Replacement, Outer Casing: passo 5, imagem 2 %32
    • You must remove the plastic cover found just above the speaker.
    • Wedge the plastic opening tool under the cover and apply pressure in an upward direction.
    • There are four clips that you are removing. When disengaged, these clips will make a snapping noise.
    • Though the snapping noise is normal, take care not to break these clips.
    Pergunte ao FixBot
    Comentar
  6. OnHub Speaker Replacement: passo 6, imagem 1 %32
    • Upon removing the cover, four screws and the speaker housing will be exposed.
    • Unscrew the four 12mm screws using a #1 Phillips head screwdriver.
    • This unlocks the speaker housing and antenna array from the casing.
    Pergunte ao FixBot
    Comentar
  7. OnHub Speaker Replacement: passo 7, imagem 1 %32 OnHub Speaker Replacement: passo 7, imagem 2 %32
    • On the bottom of the OnHub is two screws holding the casing to the base.
    • To access these screws, you must remove the rubber pad that is glued to the base.
    • To remove the pad, slide a metal spudger under the edge of the pad. Pry the pad away from the base, removing the glue.
    • Once the pad is pulled up enough to grab, peel it the rest of the way exposing the screws.
    • The rubber pad is thin and fragile; be careful not to tear when removing.
    Pergunte ao FixBot
    Comentar
  8. OnHub Speaker Replacement: passo 8, imagem 1 %32
    • Remove the two 12mm screws under the base of the OnHub by using a #1 Phillips head screwdriver.
    Pergunte ao FixBot
    Comentar
  9. OnHub Speaker Replacement: passo 9, imagem 1 %32 OnHub Speaker Replacement: passo 9, imagem 2 %32
    • Once the two screws are removed from the base, it is time to split the casing apart.
    • It is okay if a couple clips break. It will still hold together with a few remaining.
    • Wedge a spudger between the two casing halves, and pry the clips apart starting from the top
    • There are three hooking style clips in total.
    Pergunte ao FixBot
    Comentar
  10. OnHub Speaker Replacement: passo 10, imagem 1 %32
    • Once unclipped, you can slide the two casing halves apart, and remove the casing.
    Pergunte ao FixBot
    Comentar
  11. OnHub Speaker Replacement, Speaker: passo 11, imagem 1 %32 OnHub Speaker Replacement, Speaker: passo 11, imagem 2 %32
    • Underneath the speaker is an intertwined black and white wire.
    • Disconnect the wire from its connection to the motherboard.
    Pergunte ao FixBot
    Comentar
  12. OnHub Speaker Replacement: passo 12, imagem 1 %32
    • The speaker should now easily come off with a firm grip on the OnHub device and pull.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Mahir Abdella
Membro desde: 02/10/16
331 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 3-3, Sullivan Spring 2016 Membro de USF Tampa, Team 3-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G3
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 1,111
