Ir para o conteúdo principal
Oculus Rift Control Box Motherboard Replacement
O que você precisa
  1. Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: passo 1, imagem 1 %32 Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: passo 1, imagem 2 %32 Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: passo 1, imagem 3 %32
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
    Pergunte ao FixBot
    Comentar
  2. Oculus Rift Control Box Motherboard Replacement: passo 2, imagem 1 %32 Oculus Rift Control Box Motherboard Replacement: passo 2, imagem 2 %32 Oculus Rift Control Box Motherboard Replacement: passo 2, imagem 3 %32
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
    Pergunte ao FixBot
    Comentar
  3. Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: passo 3, imagem 1 %32 Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: passo 3, imagem 2 %32 Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: passo 3, imagem 3 %32
    • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
    • When the DVI connector has cleared the casing, lift the motherboard.
    • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
    • When reassembling the device, ensure that all of the wires are clear of the buttons.
    Pergunte ao FixBot
    Comentar
  4. Oculus Rift Control Box Motherboard Replacement: passo 4, imagem 1 %32 Oculus Rift Control Box Motherboard Replacement: passo 4, imagem 2 %32 Oculus Rift Control Box Motherboard Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
    • Do so for both of the wires attached to the motherboard.
    • Now fully separate the motherboard from the control box casing.
    Pergunte ao FixBot
    Comentar
Conclusão
Audrey Chan
Membro desde: 01/12/15
201 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 70-5, Forte Winter 2015 Membro de Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 39
Ao todo: 1,515
