Introdução
If you noticed your volume buttons are not controlling your volume, and you have tried other methods of raising and lowering your volume, this guide will show you how to replace the volume buttons.
O que você precisa
Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
Using the blue plastic opening tool, place the lip of the tool underneath the battery as seen in the photo.
Ferramenta utilizada neste passo:Tweezers$3.99
Use the angled tweezers to disconnect the black power cable from the mother board. The Cable should pop up from its slot when pulled.
While using the black plastic spudger tool, slowly lift the tape with your fingers and hold the wires down with the tool.
Ferramenta utilizada neste passo:Tweezers$4.99
Carefully remove the audio input films for each speaker from their respective ZIF (zero insertion force) connectors. These are the paper thin ribbons that have orange stripes along them.
Pull up the white latch on the ZIF connector, which will release the film and allow you to pull it out with tweezers.
Repeat this for both speakers.
Using the tweezers or your fingers lift the remaining black wires from the motherboard.
Here are the button switches that are pushed for your Volume Control.
This is your power button switch.
Uma outra pessoa concluiu este guia.
