Ir para o conteúdo principal
NuVision Duo 11 Battery Replacement
O que você precisa
    1. NuVision Duo 11 Battery Replacement, Back Panel: passo 1, imagem 1 %32
      • Place the flat end of a nylon spudger in the gap between the cover and the rest of the device.
      • Slide the spudger down each side until you hear numerous clicks.
      • Remove the back panel from the tablet.
      Pergunte ao FixBot
      Comentar
    1. NuVision Duo 11 Battery Replacement, Battery: passo 2, imagem 1 %32 NuVision Duo 11 Battery Replacement, Battery: passo 2, imagem 2 %32
      • Carefully remove any pieces of electrical tape that may be adhered to the battery.
      • The tape may be adhered to wires; be sure to pull up the tape slowly.
      Pergunte ao FixBot
      Comentar
    2. NuVision Duo 11 Battery Replacement: passo 3, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    3. NuVision Duo 11 Battery Replacement: passo 4, imagem 1 %32
      • Gently peel the battery from the front case.
      • You will be met with some resistance, so it is critical that you are very careful.
      • DO NOT puncture or bend the battery. It may explode or leak toxic chemicals.
      Pergunte ao FixBot
      Comentar
Conclusão
Gavin Amaral
Membro desde: 03/16/23
377 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 34
Ao todo: 770
