Ir para o conteúdo principal
Nostalgia Electrics PCM805 Motor Replacement
O que você precisa
    1. Nostalgia Electrics PCM805 Motor Replacement, Unscrewing the base: passo 1, imagem 1 %32 Nostalgia Electrics PCM805 Motor Replacement, Unscrewing the base: passo 1, imagem 2 %32
      • Unplug the device before following this guide.
      • First, place the device on its side, making sure the switch is not facing down.
      • Remove the eight 12mm Phillips #02 screws from the base.
      Pergunte ao FixBot
      Comentar
    2. Nostalgia Electrics PCM805 Motor Replacement: passo 2, imagem 1 %32
      • Gently separate the panel from the device.
      • Be sure not to tug at the wires that are still connected.
      Pergunte ao FixBot
      Comentar
    1. Nostalgia Electrics PCM805 Motor Replacement, Nostalgia Electrics PCM805 Wiring Teardown: passo 3, imagem 1 %32 Nostalgia Electrics PCM805 Motor Replacement, Nostalgia Electrics PCM805 Wiring Teardown: passo 3, imagem 2 %32
      • Locate the tie strap holding the wires and cut with a pair of scissors.
      • Use care not to snip the wires.
      Pergunte ao FixBot
      Comentar
    2. Nostalgia Electrics PCM805 Motor Replacement: passo 4, imagem 1 %32 Nostalgia Electrics PCM805 Motor Replacement: passo 4, imagem 2 %32 Nostalgia Electrics PCM805 Motor Replacement: passo 4, imagem 3 %32
      • Make note of the wiring arrangement of each bundle before this step.
      • Using wire cutters, cut each wire as close to the wire connector as possible.
      • Cut the wires in both bundles.
      • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
      Pergunte ao FixBot
      Comentar
    1. Nostalgia Electrics PCM805 Motor Replacement, Motor: passo 5, imagem 1 %32 Nostalgia Electrics PCM805 Motor Replacement, Motor: passo 5, imagem 2 %32
      • Remove the four 12mm Phillips #02 screws to free the motor housing.
      Pergunte ao FixBot
      Comentar
    2. Nostalgia Electrics PCM805 Motor Replacement: passo 6, imagem 1 %32 Nostalgia Electrics PCM805 Motor Replacement: passo 6, imagem 2 %32
      • Line up the prongs on the motor shaft with the holes in the heating element and pull the motor out.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 3-5, Hickman Winter 2015 Membro de USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Membros
Autoria de 16 guias
2Comentários do guia
Hello.
I purchased this item in a red variation from VAT19. It does not work but the light comes on. I live in the UK and we have a higher Voltage(240V) running in our domestic supply.
Something may have blown.
Can you advise what is it likely to be?
If there is a part that we can replace, can you advise which one and where I can purchase it from please?
Moh - Responder Compartilhar
Hi, I need the cotton machine from the nostalgia cotton sugar machine and I don't know where to get it. can you help me? My email is terebcn18@hotmail.com
Teresa gb - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 53
Ao todo: 3,792
