Ir para o conteúdo principal
How to rewire a Nostalgia Electrics PCM805
O que você precisa
  1. How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: passo 1, imagem 1 %32 How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: passo 1, imagem 2 %32
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  2. How to rewire a Nostalgia Electrics PCM805: passo 2, imagem 1 %32 How to rewire a Nostalgia Electrics PCM805: passo 2, imagem 2 %32 How to rewire a Nostalgia Electrics PCM805: passo 2, imagem 3 %32
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  3. How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: passo 3, imagem 1 %32 How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: passo 3, imagem 2 %32
    • Using the wire stripper, remove 1/2 inch of the wire insulation at the end of each wire to expose the bare wire for re-connection.
  4. How to rewire a Nostalgia Electrics PCM805: passo 4, imagem 1 %32 How to rewire a Nostalgia Electrics PCM805: passo 4, imagem 2 %32 How to rewire a Nostalgia Electrics PCM805: passo 4, imagem 3 %32
    • Twist the exposed ends of the wires so that they stay together.
    • Push the wire cap onto the exposed ends while holding the wires and twist in a clock-wise direction until it is tight.
    • Repeat this process for both bundles of wires.
    • Do not attempt to power on the device without the wire caps on or mix wires between the bundles.
Linha de Chegada
Carlton
Membro desde: 01/13/15
672 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-5, Hickman Winter 2015 Membro de USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Membros
Autoria de 8 guias
1Comentário do guia
DO NOT TRY THIS..it broke my machine TO NOT TRY THIS
Izzy - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 7
Ao todo: 859
