Ir para o conteúdo principal
Nook Simple Touch with GlowLight Screen Replacement
O que você precisa
  1. Nook Simple Touch with GlowLight Screen Replacement, Power Button: passo 1, imagem 1 %32
    • Place the Nook with the screen facing down.
    Pergunte ao FixBot
    Comentar
  2. Nook Simple Touch with GlowLight Screen Replacement: passo 2, imagem 1 %32
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
    Pergunte ao FixBot
    Comentar
  3. Nook Simple Touch with GlowLight Screen Replacement: passo 3, imagem 1 %32
    • Using your fingers, gently remove the power button.
    Pergunte ao FixBot
    Comentar
  4. Nook Simple Touch with GlowLight Screen Replacement, Back Cover: passo 4, imagem 1 %32
    • Remove the single screw using a T4 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Nook Simple Touch with GlowLight Screen Replacement: passo 5, imagem 1 %32
    • Slide the back cover down towards you in the direction of the charging port.
    Pergunte ao FixBot
    Comentar
  6. Nook Simple Touch with GlowLight Screen Replacement, Battery: passo 6, imagem 1 %32 Nook Simple Touch with GlowLight Screen Replacement, Battery: passo 6, imagem 2 %32
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
    Pergunte ao FixBot
    Comentar
  7. Nook Simple Touch with GlowLight Screen Replacement, Motherboard: passo 7, imagem 1 %32
    • Remove eleven screws from the motherboard using the T4 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. Nook Simple Touch with GlowLight Screen Replacement: passo 8, imagem 1 %32 Nook Simple Touch with GlowLight Screen Replacement: passo 8, imagem 2 %32 Nook Simple Touch with GlowLight Screen Replacement: passo 8, imagem 3 %32
    • Disconnect the orange ribbon cable from the motherboard.
    • Using your fingers, gently lift the motherboard from the display.
    Pergunte ao FixBot
    Comentar
  9. Nook Simple Touch with GlowLight Screen Replacement, Screen: passo 9, imagem 1 %32 Nook Simple Touch with GlowLight Screen Replacement, Screen: passo 9, imagem 2 %32
    • Insert the iFixit opening tool between the display and the front case.
    • Gently move to iFixit opening tool around the perimeter to release the set of tape strips.
    Pergunte ao FixBot
    Comentar
  10. Nook Simple Touch with GlowLight Screen Replacement: passo 10, imagem 1 %32 Nook Simple Touch with GlowLight Screen Replacement: passo 10, imagem 2 %32
    • Turn the display over. Pry the display bezel from the display assembly with the iFixit opening tool.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 74
Ao todo: 1,460
