Ir para o conteúdo principal
Nook BNRV300 Battery Replacement
O que você precisa
  1. Nook BNRV300 Battery Replacement, Power Button: passo 1, imagem 1 %32 Nook BNRV300 Battery Replacement, Power Button: passo 1, imagem 2 %32 Nook BNRV300 Battery Replacement, Power Button: passo 1, imagem 3 %32
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
    Pergunte ao FixBot
    Comentar
  2. Nook BNRV300 Battery Replacement: passo 2, imagem 1 %32
    • Using your fingers, take off the power button.
    Pergunte ao FixBot
    Comentar
  3. Nook BNRV300 Battery Replacement, Back Cover: passo 3, imagem 1 %32 Nook BNRV300 Battery Replacement, Back Cover: passo 3, imagem 2 %32 Nook BNRV300 Battery Replacement, Back Cover: passo 3, imagem 3 %32
    • Peel off the white sticker that is covering the screw head.
    • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Nook BNRV300 Battery Replacement: passo 4, imagem 1 %32
    • Slide the back cover down towards the USB port to release the back cover.
    • The pictures show the case being pried open, but do not do this unless it is necessary.
    Pergunte ao FixBot
    Comentar
  5. Nook BNRV300 Battery Replacement: passo 5, imagem 1 %32 Nook BNRV300 Battery Replacement: passo 5, imagem 2 %32 Nook BNRV300 Battery Replacement: passo 5, imagem 3 %32
    • Use a spudger or your fingers to gently pry the connector out of the white socket.
    • The back cover is now fully detached.
    Pergunte ao FixBot
    Comentar
  6. Nook BNRV300 Battery Replacement: passo 6, imagem 1 %32 Nook BNRV300 Battery Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
    Pergunte ao FixBot
    Comentar
  7. Nook BNRV300 Battery Replacement, Battery: passo 7, imagem 1 %32 Nook BNRV300 Battery Replacement, Battery: passo 7, imagem 2 %32 Nook BNRV300 Battery Replacement, Battery: passo 7, imagem 3 %32
    • The battery is located on the inside back cover of the Nook.
    • Do not use metal tools when prying up the battery. This may puncture the battery and cause harm to you and/or your device.
    • Insert a nylon spudger beneath the clear plastic adhesive holding the battery to the back cover.
    • Work around the battery, peeling up all of the adhesive.
    Pergunte ao FixBot
    Comentar
  8. Nook BNRV300 Battery Replacement: passo 8, imagem 1 %32 Nook BNRV300 Battery Replacement: passo 8, imagem 2 %32
    • Hold on to one of the adhesive tabs and pull up.
    • This will fully remove the battery from its compartment.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
1Comentário do guia
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 81
Ao todo: 4,959
