Ir para o conteúdo principal
Nokia 6085h Front LCD Display
O que você precisa
  1. Nokia 6085h Front LCD Display, Battery: passo 1, imagem 1 %32
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
    Pergunte ao FixBot
    Comentar
  2. Nokia 6085h Front LCD Display: passo 2, imagem 1 %32
    • Remove the phone's battery.
    Pergunte ao FixBot
    Comentar
  3. Nokia 6085h Front LCD Display, Front LCD Display: passo 3, imagem 1 %32 Nokia 6085h Front LCD Display, Front LCD Display: passo 3, imagem 2 %32 Nokia 6085h Front LCD Display, Front LCD Display: passo 3, imagem 3 %32
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
    • Make sure to disconnect each of the five clips before proceeding to the next step.
    • There are two clips on each side of the phone and one on the top.
    Pergunte ao FixBot
    Comentar
  4. Nokia 6085h Front LCD Display: passo 4, imagem 1 %32 Nokia 6085h Front LCD Display: passo 4, imagem 2 %32
    • Remove the four 3.2 mm screws from the front panel using a T6 Torx screwdriver.
    • The fourth screw is located under a fold in the ribbon cable.
    Pergunte ao FixBot
    Comentar
  5. Nokia 6085h Front LCD Display: passo 5, imagem 1 %32 Nokia 6085h Front LCD Display: passo 5, imagem 2 %32 Nokia 6085h Front LCD Display: passo 5, imagem 3 %32
    • Starting in the lower right corner, slowly begin to lift the tape that is holding down the front LCD and cables.
    • Be careful around the two ribbon cables attached to the tape. These cables are fragile.
    • Lift the tape from the board.
    Pergunte ao FixBot
    Comentar
  6. Nokia 6085h Front LCD Display: passo 6, imagem 1 %32
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
    Pergunte ao FixBot
    Comentar
  7. Nokia 6085h Front LCD Display: passo 7, imagem 1 %32 Nokia 6085h Front LCD Display: passo 7, imagem 2 %32 Nokia 6085h Front LCD Display: passo 7, imagem 3 %32
    • Using a plastic opening tool, slowly pry the LCD display from the bottom, releasing it from the glue that is holding it to the board.
    Pergunte ao FixBot
    Comentar
Conclusão
Brett Balcer
Membro desde: 10/04/10
240 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-46, Amido Fall 2010 Membro de Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 44
Ao todo: 1,628
