Ir para o conteúdo principal
Nobis NB07 Speaker Replacement
O que você precisa
    1. Nobis NB07 Speaker Replacement, Opening the case: passo 1, imagem 1 %32
      • Look towards the topside of the tablet, where the power button is located.
      • Insert a plastic opening tool in the crack between the two parts of the case.
      • Move it gently back and forth to open the case.
      Pergunte ao FixBot
      Comentar
    2. Nobis NB07 Speaker Replacement: passo 2, imagem 1 %32 Nobis NB07 Speaker Replacement: passo 2, imagem 2 %32 Nobis NB07 Speaker Replacement: passo 2, imagem 3 %32
      • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
      • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
      Pergunte ao FixBot
      Comentar
    3. Nobis NB07 Speaker Replacement, Replacing the battery: passo 3, imagem 1 %32 Nobis NB07 Speaker Replacement, Replacing the battery: passo 3, imagem 2 %32 Nobis NB07 Speaker Replacement, Replacing the battery: passo 3, imagem 3 %32
      • Remove the tape holding the battery in place.
      Pergunte ao FixBot
      Comentar
    4. Nobis NB07 Speaker Replacement: passo 4, imagem 1 %32 Nobis NB07 Speaker Replacement: passo 4, imagem 2 %32 Nobis NB07 Speaker Replacement: passo 4, imagem 3 %32
      • Insert the flat end of the spudger tool in the crack beneath the battery.
      • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
      • This is a soft battery, so a little bending is expected.
      Pergunte ao FixBot
      Comentar
    5. Nobis NB07 Speaker Replacement: passo 5, imagem 1 %32
      • After the battery is unglued, locate the cables that connect it to the motherboard.
      • Annotate where each color goes to make the reassembly easier.
      Pergunte ao FixBot
      Comentar
    6. Nobis NB07 Speaker Replacement: passo 6, imagem 1 %32 Nobis NB07 Speaker Replacement: passo 6, imagem 2 %32
      • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
      • Review the Ifixit soldering guide if you need help soldering.
      • You can now remove the battery.
      Pergunte ao FixBot
      Comentar
    1. Nobis NB07 Speaker Replacement, Removing the speaker: passo 7, imagem 1 %32 Nobis NB07 Speaker Replacement, Removing the speaker: passo 7, imagem 2 %32 Nobis NB07 Speaker Replacement, Removing the speaker: passo 7, imagem 3 %32
      • Remove the tape holding the speaker in its socket.
      Pergunte ao FixBot
      Comentar
    2. Nobis NB07 Speaker Replacement: passo 8, imagem 1 %32 Nobis NB07 Speaker Replacement: passo 8, imagem 2 %32
      • After you remove the tape, remove the speaker from its socket. You can place the speaker on one side of the tablet to have more freedom.
      • Look for the place where the speaker's cables meet with the motherboard.
      • Annotate where which color goes to make the reassembly easier.
      Pergunte ao FixBot
      Comentar
    3. Nobis NB07 Speaker Replacement: passo 9, imagem 1 %32 Nobis NB07 Speaker Replacement: passo 9, imagem 2 %32
      • Use a soldering iron to desolder the cables and extract the solder using a desoldering braid.
      • You can now remove the speaker.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 5-5, Brown Winter 2015 Membro de USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 Membros
Autoria de 11 guias
2Comentários do guia
How can I restore the memory on these tablets - were having problems with this tablet please help us
annievvtait07 - Responder Compartilhar
This is my favourite online game mahjong games online i have some time play.
conor mcgregor - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 564
