Ir para o conteúdo principal
Nobis NB07 Microphone Replacement
O que você precisa
    1. Nobis NB07 Microphone Replacement, Opening the case: passo 1, imagem 1 %32
      • Look towards the topside of the tablet, where the power button is located.
      • Insert a plastic opening tool in the crack between the two parts of the case.
      • Move it gently back and forth to open the case.
      Pergunte ao FixBot
      Comentar
    2. Nobis NB07 Microphone Replacement: passo 2, imagem 1 %32 Nobis NB07 Microphone Replacement: passo 2, imagem 2 %32 Nobis NB07 Microphone Replacement: passo 2, imagem 3 %32
      • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
      • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
      Pergunte ao FixBot
      Comentar
    3. Nobis NB07 Microphone Replacement, Replacing the battery: passo 3, imagem 1 %32 Nobis NB07 Microphone Replacement, Replacing the battery: passo 3, imagem 2 %32 Nobis NB07 Microphone Replacement, Replacing the battery: passo 3, imagem 3 %32
      • Remove the tape holding the battery in place.
      Pergunte ao FixBot
      Comentar
    4. Nobis NB07 Microphone Replacement: passo 4, imagem 1 %32 Nobis NB07 Microphone Replacement: passo 4, imagem 2 %32 Nobis NB07 Microphone Replacement: passo 4, imagem 3 %32
      • Insert the flat end of the spudger tool in the crack beneath the battery.
      • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
      • This is a soft battery, so a little bending is expected.
      Pergunte ao FixBot
      Comentar
    5. Nobis NB07 Microphone Replacement: passo 5, imagem 1 %32
      • After the battery is unglued, locate the cables that connect it to the motherboard.
      • Annotate where each color goes to make the reassembly easier.
      Pergunte ao FixBot
      Comentar
    6. Nobis NB07 Microphone Replacement: passo 6, imagem 1 %32 Nobis NB07 Microphone Replacement: passo 6, imagem 2 %32
      • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
      • Review the Ifixit soldering guide if you need help soldering.
      • You can now remove the battery.
      Pergunte ao FixBot
      Comentar
    1. Nobis NB07 Microphone Replacement, Removing the cameras: passo 7, imagem 1 %32 Nobis NB07 Microphone Replacement, Removing the cameras: passo 7, imagem 2 %32 Nobis NB07 Microphone Replacement, Removing the cameras: passo 7, imagem 3 %32
      • Remove the black tape covering the cameras power cable.
      Pergunte ao FixBot
      Comentar
    2. Nobis NB07 Microphone Replacement: passo 8, imagem 1 %32 Nobis NB07 Microphone Replacement: passo 8, imagem 2 %32
      • Use the spudger tool to pry upwards the ZIF connector and release the power cable.
      Pergunte ao FixBot
      Comentar
    3. Nobis NB07 Microphone Replacement: passo 9, imagem 1 %32 Nobis NB07 Microphone Replacement: passo 9, imagem 2 %32 Nobis NB07 Microphone Replacement: passo 9, imagem 3 %32
      Ferramenta utilizada neste passo:
      • With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard.
      • Using tweezers, carefully grab the front camera and twist slowly.
      • The camera should release easily, do not twist too hard.
      • You can now remove the cameras.
      Pergunte ao FixBot
      Comentar
    1. Nobis NB07 Microphone Replacement, Removing the microphone: passo 10, imagem 1 %32
      • Locate the microphone's cables in front of the cameras' ZIF connector.
      Pergunte ao FixBot
      Comentar
    2. Nobis NB07 Microphone Replacement: passo 11, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    3. Nobis NB07 Microphone Replacement: passo 12, imagem 1 %32 Nobis NB07 Microphone Replacement: passo 12, imagem 2 %32
      • Use the pointy end of the tweezers to retrieve the microphone from its socket.
      • You can now remove the microphone.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 5-5, Brown Winter 2015 Membro de USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 494
