Ir para o conteúdo principal
Nobis NB07 Battery Replacement
O que você precisa
    1. Nobis NB07 Battery Replacement, Opening the case: passo 1, imagem 1 %32
      • Look towards the topside of the tablet, where the power button is located.
      • Insert a plastic opening tool in the crack between the two parts of the case.
      • Move it gently back and forth to open the case.
      Pergunte ao FixBot
      Comentar
    2. Nobis NB07 Battery Replacement: passo 2, imagem 1 %32 Nobis NB07 Battery Replacement: passo 2, imagem 2 %32 Nobis NB07 Battery Replacement: passo 2, imagem 3 %32
      • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
      • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
      Pergunte ao FixBot
      Comentar
    3. Nobis NB07 Battery Replacement, Replacing the battery: passo 3, imagem 1 %32 Nobis NB07 Battery Replacement, Replacing the battery: passo 3, imagem 2 %32 Nobis NB07 Battery Replacement, Replacing the battery: passo 3, imagem 3 %32
      • Remove the tape holding the battery in place.
      Pergunte ao FixBot
      Comentar
    4. Nobis NB07 Battery Replacement: passo 4, imagem 1 %32 Nobis NB07 Battery Replacement: passo 4, imagem 2 %32 Nobis NB07 Battery Replacement: passo 4, imagem 3 %32
      • Insert the flat end of the spudger tool in the crack beneath the battery.
      • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
      • This is a soft battery, so a little bending is expected.
      Pergunte ao FixBot
      Comentar
    5. Nobis NB07 Battery Replacement: passo 5, imagem 1 %32
      • After the battery is unglued, locate the cables that connect it to the motherboard.
      • Annotate where each color goes to make the reassembly easier.
      Pergunte ao FixBot
      Comentar
    6. Nobis NB07 Battery Replacement: passo 6, imagem 1 %32 Nobis NB07 Battery Replacement: passo 6, imagem 2 %32
      • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
      • Review the Ifixit soldering guide if you need help soldering.
      • You can now remove the battery.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 5-5, Brown Winter 2015 Membro de USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 Membros
Autoria de 11 guias
1Comentário do guia
where do you find that battery? tried searching by the numbers on it and nothing
Scott Tuttle - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 31
Ao todo: 3,681
