Ir para o conteúdo principal
Nintendo Wii Drive Board Fuse Replacement
O que você precisa
  1. Nintendo Wii Drive Board Fuse Replacement, Faceplate: passo 1, imagem 1 %32 Nintendo Wii Drive Board Fuse Replacement, Faceplate: passo 1, imagem 2 %32
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
    Pergunte ao FixBot
    Comentar
  2. Nintendo Wii Drive Board Fuse Replacement: passo 2, imagem 1 %32
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
    Pergunte ao FixBot
    Comentar
  3. Nintendo Wii Drive Board Fuse Replacement: passo 3, imagem 1 %32
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
    Pergunte ao FixBot
    Comentar
  4. Nintendo Wii Drive Board Fuse Replacement: passo 4, imagem 1 %32
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
    Pergunte ao FixBot
    Comentar
  5. Nintendo Wii Drive Board Fuse Replacement: passo 5, imagem 1 %32
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
    Pergunte ao FixBot
    Comentar
  6. Nintendo Wii Drive Board Fuse Replacement: passo 6, imagem 1 %32 Nintendo Wii Drive Board Fuse Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
    Pergunte ao FixBot
    Comentar
  7. Nintendo Wii Drive Board Fuse Replacement, Outer Case: passo 7, imagem 1 %32 Nintendo Wii Drive Board Fuse Replacement, Outer Case: passo 7, imagem 2 %32 Nintendo Wii Drive Board Fuse Replacement, Outer Case: passo 7, imagem 3 %32
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
    Pergunte ao FixBot
    Comentar
  8. Nintendo Wii Drive Board Fuse Replacement: passo 8, imagem 1 %32 Nintendo Wii Drive Board Fuse Replacement: passo 8, imagem 2 %32
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
    Pergunte ao FixBot
    Comentar
  9. Nintendo Wii Drive Board Fuse Replacement: passo 9, imagem 1 %32
    • Remove the two 5 mm Phillips screws above the controller ports.
    Pergunte ao FixBot
    Comentar
  10. Nintendo Wii Drive Board Fuse Replacement: passo 10, imagem 1 %32
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
    Pergunte ao FixBot
    Comentar
  11. Nintendo Wii Drive Board Fuse Replacement: passo 11, imagem 1 %32
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
    Pergunte ao FixBot
    Comentar
  12. Nintendo Wii Drive Board Fuse Replacement: passo 12, imagem 1 %32
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
    Pergunte ao FixBot
    Comentar
  13. Nintendo Wii Drive Board Fuse Replacement: passo 13, imagem 1 %32
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex nut driver to extend your bit into the recesses and reach the screws.
    Pergunte ao FixBot
    Comentar
  14. Nintendo Wii Drive Board Fuse Replacement: passo 14, imagem 1 %32
    • Lift the outer case straight up off the body of the Wii.
    Pergunte ao FixBot
    Comentar
  15. Nintendo Wii Drive Board Fuse Replacement, DVD Drive: passo 15, imagem 1 %32 Nintendo Wii Drive Board Fuse Replacement, DVD Drive: passo 15, imagem 2 %32
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • The system time will be reset once you remove the battery door.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
    Pergunte ao FixBot
    Comentar
  16. Nintendo Wii Drive Board Fuse Replacement: passo 16, imagem 1 %32
    • Remove the 8.2 mm Tri-Point screw that was hidden beneath the battery door.
    Pergunte ao FixBot
    Comentar
  17. Nintendo Wii Drive Board Fuse Replacement: passo 17, imagem 1 %32
    • Remove the two 8.2 mm Tri-Point screws securing the DVD drive shield near the controller ports.
    Pergunte ao FixBot
    Comentar
  18. Nintendo Wii Drive Board Fuse Replacement: passo 18, imagem 1 %32
    • Be cautious as you remove the DVD shield, the edges are sharp and could cut you
    • Lift the DVD drive shield upward and remove it from the Wii.
    Pergunte ao FixBot
    Comentar
  19. Nintendo Wii Drive Board Fuse Replacement: passo 19, imagem 1 %32
    • Remove the four 9 mm Phillips screws securing the DVD drive to the bottom panel.
    Pergunte ao FixBot
    Comentar
  20. Nintendo Wii Drive Board Fuse Replacement: passo 20, imagem 1 %32
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
    Pergunte ao FixBot
    Comentar
  21. Nintendo Wii Drive Board Fuse Replacement: passo 21, imagem 1 %32
    • Pull the DVD drive power cable away from its socket on the DVD drive.
    Pergunte ao FixBot
    Comentar
  22. Nintendo Wii Drive Board Fuse Replacement: passo 22, imagem 1 %32 Nintendo Wii Drive Board Fuse Replacement: passo 22, imagem 2 %32
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
    Pergunte ao FixBot
    Comentar
  23. Nintendo Wii Drive Board Fuse Replacement, Drive Board Fuses: passo 23, imagem 1 %32
    • Measure across each fuse with a continuity meter.
    • If either fuse is open, you will need to replace it with an 0603 fuse; if one is not available, you can use a 0-ohm resistor or jumper wire for testing purposes.
    Pergunte ao FixBot
    Comentar
Conclusão
17 outras pessoas executaram este guia.
bushing
Membro desde: 04/23/10
10.502 Reputação
Autoria de 13 guias
4Comentários do guia
Soldering jumpers on those fuses is easier said than done. The left-hand fuse follows the same trace all the way to the larger solder pad above, so don't worry about bridging. But it looks like there's a cap or diode along the trace of the right-hand fuse, so solder carefully! This worked great, and got my Wii drive back to spinning without spending $80 on a new drive.
Robert Allshouse - Responder Compartilhar
If anyone could give specifications for the fuses needed, it would be very much appreciated... 0603 Fuses come in different amp ratings. I saw one person suggest elsewhere that after research he found that the ones used in this repair are 2A 0603 fuses, can anyone confirm this please before I get the wrong ones?
Thanks in advance,
James @ Retro Gaming Repair UK
Retro Gaming Repair - Responder Compartilhar
I found a datasheet for littelfuse which labels the fuse as 2A. The datasheet can be found here
http://www.littelfuse.com/data/en/data_s....
Hope this helps.
Another tip for after you know the fuse is blown instead of removing the fuse and jumpering it add a little solder on both sides of the fuse then use a lead from a resister heating up the solder and push the lead from a resistor into it then do the same for the other side.
randyhenke - Responder Compartilhar
this guide assumes you have one revision of the board....i have another revision and can only find one of the resistors
dude105tanki - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 76
Últimos 30 dias: 258
Ao todo: 69,449
