Ir para o conteúdo principal
Nintendo WaveBird Wireless Controller Joystick Replacement
O que você precisa
  1. Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: passo 1, imagem 1 %32 Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: passo 1, imagem 2 %32
    • Pull down on the battery cover release lever and pull back to remove the cover.
    Pergunte ao FixBot
    Comentar
  2. Nintendo WaveBird Wireless Controller Joystick Replacement: passo 2, imagem 1 %32
    • Remove both batteries from the device.
    Pergunte ao FixBot
    Comentar
  3. Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: passo 3, imagem 1 %32 Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: passo 3, imagem 2 %32
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    Pergunte ao FixBot
    Comentar
  4. Nintendo WaveBird Wireless Controller Joystick Replacement: passo 4, imagem 1 %32 Nintendo WaveBird Wireless Controller Joystick Replacement: passo 4, imagem 2 %32
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
    Pergunte ao FixBot
    Comentar
  5. Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: passo 5, imagem 1 %32 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: passo 5, imagem 2 %32 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    Pergunte ao FixBot
    Comentar
  6. Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: passo 6, imagem 1 %32 Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: passo 6, imagem 2 %32
    • Grab the base of the grey joystick cover with one hand and firmly hold down the rest of the controller with the other hand.
    • Pull off the grey joystick cover.
    • During reassembly, make sure the slots inside the joystick cover line up with the motherboard so it can fit back together.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 10-40, Amido Spring 2013 Membro de Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Membros
Autoria de 37 guias
1Comentário do guia
Question. My wavebird joystick wobbles a lot and gets stuck in directions I’m not inputting. Will replacing the top of the stick fix this? Or would I have to solder a new analog stick to the board?
Golgamang - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 38
Últimos 30 dias: 107
Ao todo: 11,426
